Question about Odyssey Steel 2 Ball Srt Putter
Lost one piece of plastic on Odyssey 2 ball putter. Where can I find a replacement?
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
My fairy just spins on the base and I have lost the instructions,please can you help
The defect with this toy is cheap design. What is happening is the weights at the waist are support to spin, and lift the top set wings. This causes it to take off. There is a little plastic piece inside shaped like an 8. One side of the 8 is attached to a small round ball attached to the weights (the round ball snaps into the top loop of the 8) and the other side of the 8 is attached to a plastic ball to the top wings. When off the weights hang down and so do the wings. When it starts the weights spin (lifting up) and they are suppose to lift the wings, since there attached to each other. Since the fairy has some violent crashes, the plastic 8 attachment dislodges off one of the other or both. I found on my daughters fairy both were snapped off and the small plastic 8 was laying in the waist. I reattached them and it worked fine for about 5 minutes and it came off again. Now we have lost the 8 piece and out of luck. To try and fix yourself. You can twist off the legs (just turn counter clockwise while pulling lightly). Once the legs are off lift the head off. A stem is attached with a washer, don't lose the washer. Look inside the waist and you will see the little plastic balls hanging off the side of the weights and wings. To fix just snap the 8 piece over the round balls. Probably won't last long because the plastic is already damaged some what and will come off easier each time it reattached. You will need a very small screwdriver to reach down to snap on or dental tools.
Jan 27, 2014 | Spin Master Flutterbye Flying Fairy Doll...
Fixing a worn-down putter face
most golf stores can replace the face plate for about $25 but you can buy the part and do it yourself part $7 and a bottle of contact cement $3
Sep 04, 2012 | Odyssey Steel 2 Ball Srt Putter
I've lost one of the "balls" on a two ball putter and would like to find a replacement ... do you know where I can get one?
I would suggest you go to your local vinyl sign maker get him to cut a new pre stick disc and stick it on
Dec 27, 2010 | Odyssey Steel 2 Ball Srt Putter
Need top left shelf runner. fell to bits
Hello, This is common with Asko after a period of use, the heat makes the plastic pieces brittle over time or amount of use. If you still have the ball bearings good, ( 4 per side ) keep them and you'll only need to replace the gray plastic pieces known as the guide rail "ball holders". If you don't have all the ball bearings, get yourself a telescopic magnet and make sure one or more hasn't found it's way into the wash or drain pump as they have a tendency to do so. This obviously can and will cause serious problems because the wash & drain impellers are plastic...steel vs. plastic = not good. The Asko part number for the holder is 8058638 and should come as individuals so order 2, one for each side. The ball bearings are # 8057977 and as mentioned, require 4 on each rail/side. As for where ? I use Amre Supply, so you could check out their on-line availability at amresupply.com if you'd like. Hope that helps solve your problem. Thank you for coming to "fixya" for your solution. Let me know if I can assist you further and good luck. macmarkus :)
Apr 05, 2010 | Asko D1876 Dishwasher
Where can i get replacement white disc's for my 2
where can i get replacement white disc for odyssey 2 ball putter?
Dec 14, 2009 | Odyssey Steel 2 Ball Srt Putter
Drivers seat is tilting back and forth, a bar underneth is broken
it can be a spring that came loose from its spot under the seat look to where it should be or the seat could be back to far and it depends on how old it is if it has just broke down make sure nothing it in the way and the lever id not stuck hope this was helpful:)
Nov 16, 2009 | Odyssey Steel 2 Ball Srt Putter
I am trying to remove the shaft from an Odyssey 2-ball putter and can't get it off. I have used a heat gun and a tourch to no avail. It appears to be an "over the hosel" attachment but none the less the...
Rosemary, I found a broken Ping putter in the trash can and took it to a golf repair place and they put a new shaft in for not too much money and it was a great putter for many years before I needed a belly putter to help me keep the putter more steady.
Nov 13, 2009 | Odyssey Steel 2 Ball Srt Putter
How do i replace a broken wiper lever on the steering column of my 2002 Honda Odyssey van?
You can try using super glue jell to glue it back together cost's a $1.00 and if you can get two ice cream sticks to go in the place where it is broken you can cut the sticks to fit and glue then on each side of the broken area on the side where you push up or down. this is a temp fix but can work if you do it right. If you can't get a ice cream stick then try to find a piece of plastic tubing and make it about 1/2 long before and after the break and then apply super glue to the plastic and slide it over the lever and push the two broken pieces together and slide the plastic tubing over it and hold it in place for a couple of minutes once it has set up for 1/2 try it to see if it works. if it holds you got it made if not the professional way is to replace the switch assembly. let me know if you need more help. I gave you the back yard way to do it but if you want to replace it post to the e-mail you get and let me know and I will give you detailed information to replace the arm. It requires three tool you may not have but can rent at most auto stores.
Nov 06, 2009 | 2001 Honda Odyssey
Remove right front fender on 2005 odyssey
NO 2 BOLTS ON TOP OF FENDER UNDER HOOD 1 BOLT BEHIND PLASTIC TRIM BY MIRROR PULL THIS PIECE BACK TOWARDS MIRROR OR IT WILL BREAK TABS OFF 1 BOLT UNDER ROCKER TRIM 1 SCREW INTO ROCKER AND 1 SCREW BEHIND PLASTIC SHROUD GOING INTO BUMPER FROM UNDER NEATH PULL BUMPER BACK SLIGHTY AND YOU WILL SEE A WHITE PLASTIC CLIP PULL BACK AND BEHIND THIS IS A BOLT REMOVE HEADLIGHT CLIP FROM FENDER AND LOSEN BOLT BY HINGE NOW FENDER SHOULD COME RIGHT OFF BOOK IS 2 HOURS TAKES 1 HOUR TO REMOVE BUT GOES ON IN ABOUT 30 NINUTES
Mar 16, 2009 | 2005 Honda Odyssey
Odyssey Steel 2 Ball Srt Putter Logo
66 people viewed this question
Top Odyssey Sport & Outdoor - Others Experts
Are you an Odyssey Sport and Outdoor - Other Expert? Answer questions, earn points and help others
