I have hot water but the central heating has stopped working
  • 3,287 Answers
Your heating system is separate from your domestic hot water. This means that you probably have an electric or gas appliance dedicated to heat water for your home.
Your problem will be found with your furnace or fuel supply. Since it is not unusual to heat water with a different fuel (electric, gas, etc.) than you do to heat your home, one can work while the other does not. Your first check should be to determine which energy source is required for your home to be heated. Home Heating Oil, Natural Gas and Propane are very common fuels. Additionally, many of these systems require some sort of electric supply to provide power for controls, pumps, sensors, etc.
Check for blown fuses and tripped circuit breakers in the electrical panel. Restore any failed circuit found. Check fuel level gauges. Arrange for refueling if you are out of fuel. If heating with Home Heating Oil, the delivery driver will probably need to manually prime and start your furnace before it will work automatically again.
You may also have a defective thermostat, control or sensor. Additionally, the furnace may have detected an unsafe condition when last run, and shut down as a safety precaution. If any of these things have happened, you'll probably need to have a pro check it out and make the required repairs for you. You could start by contacting your fuel company to see if they offer service. Otherwise, check telephone listings for someone that does.
Hopefully, this helps you atleast find someone who can get the heat back on for you - good luck!
Posted on Nov 10, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Central heating not working but hot water is ok.
If when you turn power off you wait a while it is probably not the central system coming on. You have a triple aquastat that maintains a temperature level needed to provide hot water. but you are not getting the thermostat to operate the central heating. The thermostat is a switch that operates by temperature. if you have tried raising the thermostat and the system did nor kick in. try jumping the thermostat terminals in the aquastat . if that works then the problem is either in the thermostat or the wiring to the thermostat. also with a electrical tester." while the thermostat is jumped" test the c1 and c2 terminals to see if power is going to the circulator. If not then you need a new aquastat. if you have power and the pump is not moving water replace it.
Oct 13, 2014 | Water Heaters
Pump running all of the time
one of the valve is sticking open calling for heat or hot water , or cylinderstat is calling or pump over run on boiler is not working
May 30, 2010 | Heating & Cooling
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
No central heating. Bled radiators but still nothing. Hit Re-set switch and now no central heating or hot water. Help!
check the pump,circulation not working will stop boiler at flow switch.
if pump working then check flow switch
Oct 09, 2009 | Audiovox Bosch 718 World Cellular Phone
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
