SOURCE: kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the
access of these dryers. Mostly though you yank out the filter
first.Remove the 2 screws in the filter housing on top.Then use a putty
knife to pop the top. Remove the screws holding the front panel on.
VERY IMPORTANT! Raise the front up an inch before pulling forward or
the panel clips will break! Some models have a panel on bottom. If they
do then this panel must come off first. Then you remove the door
springs and back off the screws holding down the bottom of the door
panel. Then pop the top and remove the screws on top to get the panel
out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: need diagram for belt and idler on dryer
That model number is not correct. Look here for where it's located.
http://www.appliancepartspros.com/modelnumber_locator.aspx
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
SOURCE: where are fuses located on kenmore dryer
Dryers have a thermal fuse... it's a ceramic 2-3 inch long resin-filled fuse with wires attached at both ends... near the motor...inside the dryer..
The other fuse would be your house circuit breaker panel. Check the thermal fuse..
SOURCE: dryer belt configuration diagrams for my frigidaire/kenmore
I have a kenmore dry which squeeks when drying. I out uggs in then it made noise. Its a 417
