Question about Bosch Exxcel KSR34423 Refrigerator
My fridge is minus 5 at the bottom and plus 10 at the top
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Where is the on/off switch?
Switching the power
1 Auto) Far left of the 5 buttons on the bottom
2/3 ) On the right
Minus / Plus
4 OSD functions) Second from left
5) Power: the middle button
Adjusting display settings
If the OSD is active, press Auto to exit a selection in the OSD. If the OSD is
inactive, press Auto and the monitor will automatically optimize the
position, focus, and clock of your display.
If the OSD is active, press Minus or Plus to toggle between the OSD
options. If OSD is inactive, press Minus or Plus to adjust the volume.
Press to view the OSD. Press again to enter a selection in the OSD.
Power on/off
Green: power on
Orange: in sleep mode
If the led does not light up at all then either the power lead is faulty or there is no power in the power board.
Feb 14, 2015 | Acer X222W
What temp should the fridge and freezer sit at?
Your freezer should be at minus 35, and your fridge at about 5 degrees.
Aug 07, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
2x minus x cube plus 5x minus 2
Your question is interpreted in following way as it is not clear as cube of what & minus of what?
2x minus x cube plus 5 x minus 2
Solution 1:
= 2 x -1 x cube plus 5 x minus 2
= -2x cube plus 5 x minus 2
= cube of -2 plus 5 x minus 2
= (-8 +5) x -2
= -3 x -2
= 6
Solution2:
=2x-1x cube of +5 x -2
= -2 x 125 x -2
= 500
I think logically the solution 2 must be right. How you interpret the question is important.
sonsunny
Jul 04, 2011 | Acer Computers & Internet
Candy fridge freezer seems 2 be running ok.....but freezer only does -minus 10...fridge plus 14.....back of item is nice and clean.......?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Candy CPDA241 Top Freezer Refrigerator
The refrigerator is not running cold.
most fridges are operating best at +(plus) ,-(minus)3.5 degrees C, at what setting do you have it currently? (settinngs can be between 1(one) up to 10(ten) depends on model and make). most people realize that the fridge is not cold and set the settings(fridge control) up, that is wrong, try to keep freezer build-up clean and run the fridge on a setting of 1(one). switch of the mains, clean the fridge and follow above instructions. if the problem still exists after that then you need to replace the gas
Dec 12, 2010 | Maytag MTB1954ME Top Freezer Refrigerator
Trying to convert minus c to minus f in cal plus
Here are the formulas for conversion.
Let T_C be the temperature on the Celsius scale and T_F the temperature on the Fahrenheit scale.
0 _C correspond to 32 _F
100 _C correspond to 212 _F
Generally
  1. T_C =(5/9)*(T_F -32) ; for T_F=212 _F , T_C = 5/9*(180)= 100 _C
  2. T_F= (9/5)T_C + 32 ; for T_C=100_C, T_F = (9/5)*100+32 = 212_F
Problem for you : Find the temperature which has the same value on both scales.
Jan 10, 2010 | Texas Instruments TI-84 Plus Calculator
Maytag ice20
When replaceing the highvoltage control board be careful to not handle it too much as nano voltages can burn it. Unplug before repair. Simply hook it up the way you unhooked it very easy and in the left back of the fridge. Now that it's installed plug fridge in and push back to wall. Look at model tag and write down your code something like 0304 most likely. Go to digital control hold down door alarm and freezer - minus button for 3sec. then let off door alarm now you should see PE flashing the fridge wants personality code (the one you have wrote down). Let off minus now it should show 0000 now push minus once more a decimal should show up 0.000 the decimal indicates what number your about to change. Move the decimal with freezer plus button and lower or higher number setting with fridge side buttons.Once your done hold down freezer minus till the numbers are flashing then open any door and close. Now the fridge should be working properly.Hope I helped
Dec 12, 2007 | Maytag MFD2560HES Bottom Freezer French...
Bosch Exxcel KSR34423 Refrigerator Logo
24 people viewed this question
Top Bosch Refrigerators Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
