Question about Ricoh Aficio CL7200 Laser Printer
The colors and images are printing well, but there are black streaks when it prints, especially when printing multiple copies. It seems to get worse as it is used.
  • 165 Answers
Sounds like the drum or drums needs replacing or possibly transfer belt cleaning blade not doing its job worn out or spring fell of it. Most likeley to be a drum though.
i think they r 60 or 80 k life
Posted on Nov 10, 2010
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
Free solution of black bars on paper while printing on xerox dc 12 printer
Most likely this indicates a drum cleaning blade failure. This is especially true if the black Bars run up and down the page and get worse on multiple copy runs. So if you run 10 copies the last one out will be worse than the first one out. If this is the case, cleaner blades are pretty in-expensive at around $40.00.
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
My minolta ep 4000 copier prints with thick black streaks imprinted on page. what's wrong? is it the corona, the drum, or something else?
Most likely it is the drum cleaning blade. One indicator of the drum cleaning blade going bad is that the black lines will get worse as you run multiple copies. So if you make 10 copies for example, the last copy out will be streaked worse than the first copy out. Drum cleanig blades are about $30 bucks plus whatever your local service guy charges for a svc call.
Jul 21, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Streaks on prints
Lines/streaks at the same location indicate either a speck of dust stuck on the glass or the glass may be scratched.
S. Mohan
Aug 19, 2008 | HP Photosmart s20 Film Scanner
Minolta 2300DL Printer - black streaks
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Ricoh Aficio CL7200 Laser Printer Logo
316 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
