Question about HP Photosmart D7160 InkJet Printer
Error 0cx18a0106 impresora hp photosmart D7160
nandini789
  • 430 Answers
SOURCE: how do i clean the rollers on a hp photosmart
  1. Remove the power cord from the electrical outlet. Open the printer cover and expose the printer rollers.
  2. Remove the paper from the "in" tray and any paper you may have in the "out" tray.
  3. Hold the wet cloth against the first roller with one hand and use the other hand to manually turn the roller.
  4. Replace the paper in the in tray. Plug the printer in and print a test page. The rollers should take the paper from the in tray. If not, repeat the process in Step 3 to make sure you remove all of the dirt.
A HELPFULL IMAGE:---- 261257_thumb.jpg OK. thanks.
Posted on Aug 14, 2009
pineworks
  • 4041 Answers
SOURCE: Ink system failure HP PhotosmartD7160
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: Tengo el siguiente problema: HP Photosmart 3310
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Posted on Feb 13, 2010
  • 1684 Answers
SOURCE: ink system failure, how do I reset the printer
The ink system failure is caused by air in the ink feed tubes. This happens if you allow the ink to fully run out of the cartridge and it **** air in or if you use poorly filled refill cartridges that have air bubbles. To clear the error you will need to perform a purge on the ink lines to clear the air out. We have a step by step guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The process will take about 10 minutes to finish but then you should have a fully functional printer again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on May 28, 2010
  • 30 Answers
SOURCE: tengo una impresora multifuncional hp
1) connect printer directly to wall
2) try different walloutlets
3) remove the ink cartridge and then clean it with a lint free cloth.. clean the printheads as well.
4) the unplug the power chord from the back of the printer and then press and hold the power button for 30 sec.. replug the power chord.
5) replace printheads as well as cartridges
6) service the product
Posted on Mar 27, 2011
HP photosmart D7160, ink sys failuar error code:
Hi otissr
If you are lucky, the solution given by HP in the following link will help.
Hope you wouldn't require a service call.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01936219&cc=us&lc=en&dlc=en&product=1156652
Good luck
If my answer is helpful, please give a rating.
luciana44
Dec 28, 2009 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 Printer needs service?
Hp has an excellent online support site, available here, or here, as well as a user forum with q& a from other users that might help with that error.
You might want to try the solution posted in this link. It appears to have worked for quite a few folks. Read through to the end before you try it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 15, 2009 | HP Photosmart D7160 InkJet Printer
Memory card error
Memory cards larger than 2 GB are not supported with Photosmart printers
Jan 01, 2009 | HP Photosmart D7160 InkJet Printer
Hp photosmart d7160
Printer Software Installation Stalls or Stops in Windows XP with a USB-connected Product
Click Here for solution
This Will resolve the issue with the system and the printer
Dec 13, 2008 | HP Photosmart D7160 InkJet Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
318 people viewed this question
Seeker5211
Seeker5211
