Question about Black & Decker Bread Machine
Bread is not rising very much, I live in Canada in the summer & come to AZ for the winter, I use the same receipe but the results in AZ are not as good as at home. I bring my own flour from Canada.
    Genius:
  • Black & Decker Master
  • 1,280 Answers
Increase : liquid by one tablespoon, 1 tsp. sugar and 1/4 tsp. extra yeast.....be sure your liquid phase is between 80-90 degrees fahrenheit....please let me know if this helps and if so please vote/rate this answer or leave testimonial.....best of luck!!!
Posted on Nov 10, 2010
Can you find out wich drection a celing fan is saposto turn for winter & summer?
Hot air rises so in the winter you want to blow the warm air down. In the summer you want to draw the warm air up.
Jun 20, 2014 | Nikon Coolpix S9100 12.1mp Digital Camera...
Having to physically pour coolant every few days,winter and summer,
I assume the coolant is low when u install fresh coolant. ( No pun intended) The cooling system is a sealed system, if u are adding fluid constantly it either means u have a leak or it's burning it. Do u see any leaks, puddles or smoke coming from the engine compartment? Is the coolant mixing with the oil or visa versa, or a hot running engine? could be head gasket. Check spark plugs for coolant or oil. coolant leaking into passenger floorboard? Heater core. Poss coolant switch. If no luck, have the system pressure checked by a shop & stop wasting $ on coolant. good luck.
Aug 05, 2017 | 1996 Mercury Tracer
How often do i need to replace my fuel filter?
SIMPLE MAINT SCHEDULE , IS CHANGING IT ONCE A YEAR, but it depends where you live, If this truck is a diesel & you live in a northern climate, change your filter once a year but not until you know for ceretain that you are buying winter grade fuel, ie: nov
Reason for this is that there will be wax/parafin build up in the filter that your ran on the summer fuel, it can congeal in the filter in winter becasue of this build up. If you replace the filter in late autumn, then tat filter will not have a congeal problem because the there hasnt been anything but winter grade fuel through it, , and its safe to run all next summer , but the summers residue will cause problems next winter , so change again in late autumn .
Sep 27, 2010 | 2001 Dodge Ram 2500 Truck
What fuel is best for my Chev Malibu, 2003. I live
Standard 87 octane is all that car requires. You will gain no benefit from using mid or top grade fuel.
Most passenger car tires are run between 32 and 35 psi, regardless of season. You can look at the side of the tire to find what the max cold psi pressure is. You will normally find that it is 35psi.
As for summer/winter tires. If the wobble only happens when the snow tires are installed, and not with the summer tires, that obviously eliminates the car as being the problem. Do you have your summer and winter tires mounted on different sets of wheels, or do you swap the tires every season on the same wheels?
If they are on different sets of wheels, then the winter tires are out of balance, have some sort of damage to the carcass of the tires, or you have a bent wheel. If you are using the same wheels and swapping the tires every season, then you need to have your winter tires balanced and see if it solves the problem.
Dec 18, 2009 | 2003 Chevrolet Malibu
I have a GPS navigation system ITEM NO W3G-01 which was given to me. Can this be used in the United Kingdom? If not what can I do. I do not live in the States Or Canada. I live in LONDON, UK
In the product manual it indicates there is a SD card slot, along with a USB port, so there is a physical method to change the map data to your locale.
http://www.nextar.com/images/Product/W3G-01%20hardware%20manual-english.pdf
However, you should contact the manufacturer to see if their firmware allows you to change/add maps. Garmin GPS units have this capability, and I have used their topo & Road maps together with very good results for off-road adventures out in AZ & Utah.
Jul 13, 2009 | Nextar X4-T Car GPS Receiver
The bread only rises about half way.
After its mixed the ingredients and before it cooks, it should sit for a while to allow the mix to rise. Check that the heater is on in this period, otherwise, if its cold, it wont rise
Feb 14, 2009 | Betty Crocker BCF1690 Bread Maker
Dense bread
Try a different recipe--highly recommend The Bread Machine Cookbook by Melissa Clark it may be out of print, but can order from Amazon for less than $3.00. Also, if your bread is too dense, you can try adding a little wheat gluten flour, found in the baking section at most large grocery stores, including Walmart. However, a little of this goes a long way! I never need to add to my white bread, but it is wonderful for whole grain breads as it greatly improves the texture. Wheat gluten is made from the inside of the wheat kernel and is very high in protein, also helps your bread rise, so try starting with one teaspoon for your white bread and use up to one fourth of a cup with whole grain breads. A little of this stuff goes a long way!!!! Do read the introduction in the little paperback cookbook I recommended, it really helped me to understand the hows and whys of breadbaking, and I had to throw away many a loaf, before I read this section of the cookbook.
Dec 13, 2008 | Sunbeam 5833 ExpressBake Bread Maker
Rising cycle
Have you 'proofed' your yeast? The rise temperature is not very much above room temp, particularly in the summer months. I would expect the bread to rise at least 3/4 as much without any rise time heating.
Jul 07, 2008 | Zojirushi BBCC-V20 Home Bakery Traditional...
Black & Decker Bread Machine Logo
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
