Question about Singer Electronic Steam Press Iron
Breville ir23 steam iron
This iron auto shuts off when gets a bit warm. Just wondering how to fix it
  • AT3X Jul 26, 2008
    Hi, we have same problem. Night before my daughters wedding it decides to shut off and will not come on. Have tried emptying of water and turned off for hours. Can't find anything on Breville website.
My electronic steam press has been performing perfectly until yesterday. I can not longer get it to turn on? Any suggestions? carolb745
Posted on Oct 30, 2008
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Wonder steamer iron
Why not contact Breville for instructions?
Jul 29, 2013 | Breville 2400w Steam Iron Stainless Steel...
Breville TECHnique VIN158
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
How do i use the self clean on my breville steam iron 2400 technique
please refer to the owner manual for use. download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jul 22, 2012 | Breville Power Steam VIN208 2400 W Steam...
Iron getting power light on but not heating up and dripping water
I have a Breville Iron 2200W it went into auto shut down and now i can't get it to work
Jun 30, 2011 | Breville Irons
LIMESCALE BUILD UP
To prevent lime build-up, use distilled water instead of tap water. I buy bottles of distilled water for use in my irons and steamers and have never gotten calcium or lime build-ups.
You can buy a product by the name of CLR (stands for Calcium, Lime & Rust) which can be found at stores such as Target, Walgreens, CVS, Walmart, etc.) to wipe the build-up from your iron. You can also run this solution through your iron to clean the build-up from the inside.
May 12, 2009 | Irons
Cant get anti calc cartridges for my steam generator
I had to order mine direct from Breville. If you go to their website and contact them with the model of the iron then they will give you details of price and postage.
Aug 25, 2008 | Irons
Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Dec 23, 2007 | Irons
Singer Electronic Steam Press Iron Logo
551 people viewed this question
Top Singer Irons Experts
Sean  Piquet
Sean Piquet
Are you a Singer Iron Expert? Answer questions, earn points and help others
