Question about Zebra TLP 2844-Z Thermal Label Printer
Everytime I try to print lables, it prints one or part of one and then stops and the red light comes on. I've tried restarting it, turning it on and off. What is the problem?
    Champion:
  • Zebra Expert
  • 285 Answers
Press the botton 2 times to run calibration, if not work, press button untill flash 7 times, if not work, chek the setings from driver (if use labels with gaps, use non-continues) (if use ribbon, use Termal Transfer) chech the settings (sensor ir on GAP/Web)
Posted on Nov 12, 2010
How to stop printer from printing an extra sticker when it prints?
Hi
  • Turn the printer off.
  • Press and hold the green power button and turn on the printer.
  • Release after first flash of led light.The printer will run a test print.
  • Turn it off and then on again.
  • Now print!
Hope it helps.Thanks!
Oct 03, 2011 | Zebra LP 2844 Thermal Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
Zebra lp 2844 after printing 1 label , light change to red.
me have same problemo
i tried to update the frimware but still have problem
i think problem about lables? did u try bigger lables?
May 14, 2009 | Office Equipment & Supplies
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
Lanier 5645 cannot reset printer red button just keeps coming on
when you press the 'red' button, it probably says 'paper mismatch, or load "XXX" paper, and you can override it by selecting one of your paper trays manually? It is likely a "legal size document' and you don't have legal size paper loaded, or something along those lines. Try printing the document after manually selecting the paper size/tray (turning off auto paper select) in your printer preferences dialog box on your PC first.
Mar 02, 2009 | Lanier Office Equipment & Supplies
Issue trying to print mulitple labels, red light
The physical label size must be set in the printer driver, both in the "Properties" and the "Default" tabs.
Jan 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
My printer won't print
Hi
Are you using XP OS, go to computer properties then go to device manager, click on universal serial bus controller, look for usb printing support, uninstall it. unplug printer usb cable from back of computer and replug it on a different usb port, try reprinting. if all fails try to reinstall driver.
Hope this help
Nov 29, 2008 | Epson Stylus Photo R1800 InkJet Printer
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
298 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
