Question about Lexmark Office Equipment & Supplies
Hello, How can I clear the paper jam notice. There is no paper jammed in my printer and i cannot get this to go away and the printer work. I have tried unpluging it and turining it on and off. Thank you
  • 2 more comments
  • Alice Yates Nov 10, 2010
    Hi I did what you said to do place thin cardboard through the rollers and there does not seen to be any paper in there. What else can i try. I tried the link to Lexmark you gave me but it it the wrong page it is for a differnt printer.
    Thank you
    I did what you said to do and still no luck. Even though the error message is jammed paper. I feel like the paper is not loading in the shoot right to begin with. Any ideals?
    Alice
  • Alice Yates Nov 11, 2010
    P4350 is the model number
    Helo I have tried all of the above. Still get error message. Model number P4350. Please help
    President:
  • 1,961 Answers
Hi!
What is the model number of your printer? please post back.
Posted on Nov 11, 2010
  • 6,993 Answers
One common paper feed problem related to Lexmark printers is a paper jam deep inside the printer. Usually this happens immediately after another piece of paper has jammed the printer. The first sheet of paper leaves behind a small torn piece of paper inside the printer. When you print another document, the next piece of paper hits the smaller piece of paper inside the printer. So, you can't print until you find the small piece of paper. To solve this problem, turn off the printer, open the front cover and look under the rollers and flap doors for the piece of paper. You may have to use something flat like a thin piece of cardboard to stick in between the flap doors to remove the paper. Once the piece of paper has been removed, turn the printer back on and resend your document to the printer.
Lastly, read the lexmark jam tips on the below link as it might be helpful.
http://www.lexmark.com/publications/pdfs/lexmarkc720/eng/jams.pdf
Good luck.
Posted on Nov 10, 2010
  • Walesarumi
    Walesarumi Nov 10, 2010
    disconnect the printer from your computer, uninstall the printer software/program from your computer's control panel, restart your computer, reinstall the printer software and try again.
    Good luck.
  • 600 Answers
Please be surethat all paper and shreds of paper have been removed. If you want to be sure, here are step by step guide made by Lexmark
lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
http://support.lexmark.com/index?page=content&actp=LIST_RECENT&id=SO4124&locale=en&userlocale=EN_US
and finally you can try to press the buttons for the paper jam error and then unplugging the unit, wait for a while then plug it back in.
If the error does not clear after the above steps, sensors or rollers may be the culprit, and as professional repair men says, there are no user serviceable parts, beyond the opening or doors,latches,lock, specially the inner parts,such as the rollers,gears and sensors, for they are quite sensitive and there is a risk of shock.
Hope the steps above clears your problem.
Thank you for using Fixya.com
Posted on Nov 13, 2010
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
Paper jammed open left cover
Hello, To solve this problem try follow this steps
1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Turn off the printer.
3. Remove any paper trays, inspect them for wrinkled or damage paper.
4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly
The goal is to keep the paper from tearing. If several pieces are jammed together,try pulling out the middle piece first to loosen the jam.
7. If the paper does tear, try rotating the roller gears manually to free the paper.
8. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks
Jun 29, 2011 | Office Equipment & Supplies
The paper is getting jammed in the printer every time.
Hello
Turn off the printer and remove any paper trays. Inspect them for wrinkled or damaged paper.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper, Don't force anything, though.
GOODLUCK
Jan 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
Clear Paper Jam, then Press OK
Have you checked the access door in the rear of the machine?
Jan 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Both power light and paper jam light on
clear the paper jam. take out the paper(if any) from back of the printer. Clear all prints in que and try to print
Aug 13, 2008 | HP DeskJet 970cxi InkJet Printer
Clear paper jam
does the printer have a cancel botton if it does push it
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Paper jam
Very frustrating ... checked all over for remaining jams - but the message "paper jam" just won't go away after clearing a paper jam. Eventually, it goes away but no way to predict how long it will take!
Feb 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Step
Step
Step
Step
5
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Jan 14, 2008 | Epson AcuLaser C900 Printer
104 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
