Question about Canon PIXMA MX310 All-In-One Printer
Mx310 printer not responding
I have installed the driver software successfully and the printer. Each time I go to print the test page it returns printer not responding.
The wires are all plugged in, the printer is on my list in the control panel?
  • 2 more comments
  • costask Jun 24, 2008
    Even if I have installed the printer driver succesfully and t appears on the Printers & Faxes list, I cannot print; I get a "Printer not responding" message.
    However I can scan, which proves that the cables are connected Ok.
  • Anonymous Aug 15, 2008
    I have the same problem - driver is on the PC, printer is listed under printers and faxes but when I try to print I get a message "printer is not responding". I checked the lead on another canon printer, so that isn't the problem.
  • PupDogDude Oct 05, 2008
    I'm having the same problem. I downloaded the drivers and the software but when I print, it says printer not responding. I'm running Vista x64. I'm guessing it's a vista problem, which wouldn't surprise me.
  • spuckett954 Oct 10, 2008
    I have the same problem. Everything but the printing works.
SOURCE: Won't print black
same thing happend to mine. Have not sorted the problem yet but you can get it to print if you change the Ink usage settings. Go into your printer properties, select maintenance tab and click on the Ink Usage Control button.Tick "Use Composite Black" then ok. This will enable you to print out your docs at least.
Posted on Jan 20, 2007
SOURCE: Canon Printer Help.
I have just got a Canon PIXMA MP210 ALL IN ONE PRINTER My CD ROM reader is not working how can I install it
Posted on Jul 27, 2008
Scott Ellin
  • 558 Answers
SOURCE: problem with canon PIXMA ip1000 printer
It might be the contact strip of the Printer which remains in touch with Cartridge going rip off for the Black one.
You need to repair it. It will not cost you much.
Let me know if I can assist you further.
Regards
Ellin
Posted on Sep 26, 2008
SOURCE: MX 310 Not seen in Mac printer list, so cannot install
Had a new hard drive installed and need to re-install Canon Pixma Mx 310 all in one back in my Mac
Posted on Jun 29, 2009
leethedeuce
  • 4472 Answers
SOURCE: Canon Pixma ip5200 under Windows 7 - not responding
Did you download the latest drivers from the website? It looks like they were posted this month. I would report the issue. It is quite likely there is a compatibility issue. Have you contacted canon at all about this problem? Once I have more information I can try and assist you further.
Thank you,
Lee
Also check out my tip on how to save money using less ink:
http://www.fixya.com/support/r3954871-save_money_using_less_ink_when_printing
Posted on Jan 27, 2010
Canon Printer MX310: I get an -30 error code; saying printer is not activated
  • Click Start and then click Printers and Faxes to open the Printers folder.
  • If the desired printer icon is missing, please go to Step two.
  • Make sure the desired printer has a check mark next to it which indicates it is set as the default printer.
  • If the desired printer does not have a check mark next to it, right-click the printer icon and then click "Set as Default Printer".
  • Right-click the printer icon, and then click Print Test Page to print a Windows self-test page.
  • If the Windows test page prints successfully, close all windows and try printing from the application you were using before.
  • If the Windows test-page does not print, go to Step two.
  • Step two: Re-install the USB Composite Device from Device Manager
aFor more help visit cbrtechsolutions
Sep 03, 2013 | Canon PIXMA MX310 All-In-One Printer
Why Canon MX310 won't scan error 114.0. how to fix
I have this copier too but only use it as a copier in my classroom. It's a stand alone. But can't print. There is no software to install on a computer so I don't know how to fix it if there's no software.
Feb 26, 2012 | Canon PIXMA MX310 All-In-One Printer
I can't connetc mx310 to my new computer. The computer is running windows vista. Do I need to download a seperate software ?
The printer drives varies with OS, even if the printer is of the same model. So goto canon website and specify your printer model and OS, download appropriate drivers and install it in Vista. Then you are good to go.
Mar 28, 2010 | Canon PIXMA MX310 All-In-One Printer
CANON PIXMA MX310: printer not responding.
If you go to Start, Printers and Faxes, if it says "Offline", right-click the printer and choose "Use Printer Online." If it says Ready, you should be good to go.
If however there is a problem yet, double-click the Printer there and see if any jobs are in the print queue. You can remove them all buy Right-Clicking and choosing "Cancel All Documents" then try printing a test page. Right-click the printer, go to properties and click "Print Test Page."
If you still have problems, follow up on your question.
Aug 29, 2009 | Canon PIXMA MX310 All-In-One Printer
I need help faxing, saying its incomplete
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Trying to install HP J4680 AIO printer and installation fails at
jim it is ur printer driver problem because ur software is damage u need to download the driver from net. or purchase a new driver.
Mar 24, 2009 | HP J4680 Office Jet All-In-One Printer
Dec 16, 2008 | Canon PIXMA MX310 All-In-One Printer
"Printer not responding" message when printing test page
Have you tried deleting and re-installing the driver? And what kind of machine are we speaking of?
Larry
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
Canon PIXMA MX310 All-In-One Printer Logo
494 people viewed this question
old marine
old marine
