Question about Whirlpool RBS245PDS Electric Single Oven
My whirlpool RBS245PTD12 oven will not start..when I turn the breaker off and turn it back on a message E3-F1 comes up
    President:
  • 2,468 Answers
If this display lasts longer than 1 minute try to hit the cancel button,if this does no good then you have what is considered an "INTERNAL ERROR" and you will need to check all wiring to and from the control board for problems,breaks,if none are found then the last option is to replace the control board
Posted on Nov 10, 2010
  • 2,299 Answers
This means that the control board is bad. And needs replaced. The part number is 961211 and costs about $185.00
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
My oven is showing a code E3 (in red) -F1- (in black). Everything works but the heat light will not stay on and it will not heat. It has a safty feature that when the electricity goes off you have to reset...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Nov 09, 2010 | Whirlpool Ovens
Error E# and F1
Hello,the error codes E3 and F1 means Wiring harness cavity size does not match previous stored valued
SOLUTION:The "Cavity Size Select"jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for.
Check the jumpers in the harness to make sure they agree with the actual oven size.
Thanks
Jun 01, 2010 | Whirlpool RBS245PDS Electric Single Oven
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven won't work
unplug wait 5 minutes and plug back up press the off button and this should allow the oven to reset and should come on
Oct 17, 2009 | Ovens
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
Error code on my oven, what does it mean?
I have a Whirlpool oven that is 10 years old or so. The oven stopped working today. The code that came up was E3 (in green) and F1 (in red). I would like to know what is wrong with the oven? Please send me a solution. Thanks
Nov 15, 2008 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 | Ovens
Whirlpool RBS245PDS Electric Single Oven Logo
55 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
