Question about Comdial 8012S-GT Corded Phone
I unplugged my 8012S-GT Telephone yesterday to clean the cover; this morning it worked fined; even checked my voice mail set up -- everything was fine; then about 45 minutes later the phone started ringing and the outside lines were blinking - now nothing except line on keeps blinking and no one is on that line -- when I pick it up the phone is dead. The speaker did work; now it doesn't work?
  • 359 Answers
SOURCE: Same Number for Fax and Telephone
The fax is designed for use with an answering machine, the greeting for which must be no longer than 15 seconds. If voice mail in this case is referring to answering machine, be certain that the message is as indicated.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Posted on Jul 02, 2008
Centernet
  • 38 Answers
SOURCE: Number of rings before going into voice mail
Depending on your system and configuration, that timer could be in any number of locations, and most of them are only available to a certified dealer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
Vit Avaya BP
  • 211 Answers
SOURCE: Ring back on 18D
If you have enough voicemail boxes go to ext 10 or 11
Press feature 00
Left intercom twice
#310
enter extension number
press 1 to assign
Feature 00
Posted on Mar 22, 2009
etirbynnor
  • 655 Answers
SOURCE: Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Posted on Mar 26, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: When I try to get my voicemail by pressing VMAIL
The only way to fix it without your vendor getting envolved is to try to reboot your voicemail server/phone switch(depending on the model of your system it can be inside of your switch or separate computer).
Your voicemail is down right now
Posted on Apr 02, 2009
GE phone model 29581 does not seem to have instructions for resetting voice mail ...my phone just keeps ringing and won't go into voice mail
Voice Mail is not a function or feature of any telephone set,
nor does the GE 29581 phone have an Answering Machine
System that might be confused with Voice Mail.
VoiceMail is an option offered by some (not all) Telephone
Service Providers. Check with your Telephone Service
Provider to learn how to go about using theirs if it's available.
The original GE 29581 phone User's Manual is available at: http://www.manualslib.com/download/59417/Ge-29581.html
Mar 18, 2016 | GE Lands Phones
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
How in the world do you set up voice mail on the e71
Hello Debb,
Please visit the link provide below :
http://www.gen-i.co.nz/Solutions/Mobility/Device_Documents/Nokia%20E71/Setting%20up%20Voicemail%20on%20the%20Nokia%20E71.pdf
Apr 15, 2011 | Nokia E71 Smartphone
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
How to set up voice mail on a new htc cell phone
Go to 'Start > Settings > Personal tab > Phone > Services tab'. You should find the voice mail settings there.
Hope it works for you.
Cheers! Carlos
May 20, 2010 | HTC Touch P3450 Smartphone
HOW DO I GET VOICE MAIL OFF MY COMDIAL 120 PHONES
Methinks the welcome message is stored in you telephone set. Try another set, or enter a new welcome messsage. Could it be that the telephone line carries two different lines. Check with you telephone company. Older service may have not been deactivated.
Just a few (possibly farfetched) leads for you to investigate.
Sep 04, 2009 | Comdial Avaya Partner ACS with Voice Mail...
How do I change the time/date stamp in voicemail on my Comdial 8012s-gt phone system
What type of vm is it, a key voice? If so what type of change do you wish to make. turning it on or off? or getting time correct?
dan
Jul 29, 2009 | Comdial 8012S-GT Corded Phone
Uniden dect 6.0 caller id light wiil not go out
I am not aware of any Uniden phone that has a "Caller ID" light. If you are talking about the small red LED on the top of the handset, that is a voice mail indicator and can be triggered by either a voice mail being held by your telephone service provider (Called Call Notes by some of the "bell" companies) or an unheard message on the telephones internal answering machine. Most of the time this is due to a voice mail on your service provider. If you don't think you have Voice Mail from your telephone service provider, call them and make sure, now days they include it with a bunch of other features without you ever asking for it. If you do not have voice mail through your telephone provider and there are no new messages on your answering machine, follow the Reset VMWI indicator procedures in your owners manual availible at http://www.uniden.com/index/manuals_results.cfm?cat+1
Apr 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Jan 13, 2018 | Panasonic KX-TG4322B Twin Cordless Phone
Comdial 8012S-GT Corded Phone Logo
90 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
