Question about GPS
Navstar sy-101 my two way handheld radio navstar sy-101 is displaying EE on the screen and cant do a thing
  • Anonymous Mar 22, 2009
    SAME PROB
The radio has deprogrammed itself and can easily be sorted out. Give me a phone call at the office and i will take you through the reprogramming process.
Jesse Schubach
Killerdeals Durban
031 313 2785
Posted on Mar 31, 2011
My TI-nspire CX CAS just got a white screen with a black stripe.
Unplug the battery? I thought that the battery was built in.
Nov 13, 2014 | Texas Instruments TI-Nspire CX CAS...
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and
the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
• While holding these keys press [on].
Please Note: For TI-Nspire Family handheld units that
contain rechargeable batteries you can alternatively hold the above
keys while pressing the [reset] button on the back of the handheld rather than
removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu
with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit
restarts.
• 2: Delete Operating System - The operating system will be deleted
without deleting any documents on the system.
• 3: Delete Document Folder
Contents - This will delete the user's documents, but will not delete the OS.
Selecting this option is the same as using the RESET hole on the back of the
unit.
• 4: Complete Format - This will delete the OS and all documents for a
total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
Trc 101 assesories
It is a handheld unit- it is not for fixed point use like a 12 volt mobile is or a base is, so your only real accessories are going to be Nickel Metal Hydride cells or Nickel Cadmium cells.
If you are wanting a fixed point use radio, get one better suited for the manner in which you are going to use it. The 101 is not suitable for use as a base station and should not be tried to be used as one.
But it is a unique piece of radio history though.,
Feb 20, 2012 | Radio Communications
My hummingbird radio keeps showing EE on screen and wont let me talk
Check the channel that you are on.. make sure it is a TX channel. also check the SWR's with another radio or mfj259b analyzer.
Either there is a problem with the radio not locking into the channel and displaying EE
or low power probs..
these are the most common probs.
Feb 15, 2011 | Radio Communications
I recently had a service which they took the battery of when reconnected it is now displaying EE wot can.there is no radio or cd
EE is external exhaust, basicly means it blows the hot air out of the case, i hope this answers your question goodluck
Jan 24, 2011 | Car Audio & Video
PGM WIRED
pgm wired how do i fix this?
Sep 19, 2009 | Radio Shack Pro-84 Handheld Scanner
Not picking up any sound
When you first turn on the pro 95 and the dual trunking screen is still on insert (gently) a pin or straightened paper clip in the small hole just above and to the right of the external power plug. That will reset the radio. Once it is reset (wait until it finishes resetting) you may need to initialize it. Turn it off then back on, while it is still displaying the dual trunking screen press "0" and then the "1". Do not turn the radio off until the Initializing is finished.
Now re program your radio if you with to use the "SCAN" button. Other wise you should be able to use the "search" button to select the service you wish to listen to.
Hope this helps.
Jan 15, 2009 | Radio Shack Pro-95 Handheld Scanner
Display on blaupunkt alicante cd30
it is not worth repairing... get a new one.
Sep 02, 2017 | Blaupunkt Louisiana DJ32 Cassette Player
EDACS beeps
got to be the relays and you can't get rid of them
Dec 22, 2007 | Radio Shack Pro-97 Handheld Scanner
Comfort aire A/C Rads 101-A EE light
Possible faulty control electronics. Call a repairman.
May 28, 2007 | Comfort-Aire RADS-151 Air Conditioner
GPS Logo
173 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
