Question about MSI 865G Neo2-PLS Motherboard
Onboard usb problems
Hi when I plug my extened usb from my tower to my onboard connector the PC frezzes up when XP loads and then none of the usb ports work
please help
  • 983 Answers
I think the capacitor near by the USB port is burned out so there is no power storage or power supply for the USB ports so just have a check with the capacitors near by the USB ports if you are good at recognizing that problem ..
otherwise just contact the motherboard technician ....
he will have a check and if the capacitor is burned out he will replace it ....
any doubts reply me
i am always here to assist you
thank you
bye
Posted on Jun 17, 2008
Where is USB plug in connector on PC tower? is not on front
hey, im sure the e4200 dont have front usb port.
but there should be 2 underneath the ps2 (keyboard & mouse) socket.
Jun 18, 2012 | Computers & Internet
I can't use printer from computer,all it's saying on the instructions I got was, plug power in and ubs cord to printer,nothing hooked into my tower, go figure???? so how do I do it,it's a new computer,just...
Plug the USB cord from the printer to an available USB connector on your tower, insert printer disk into computer drive, then go through Printer Setup and you should be able to print.
Dec 14, 2009 | HP Ruggedized DC Car Adapter for HP...
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
Pc tower gets very hot, and is starting to frezze during work ,
If this unit is enough to feel it, then your fan(s) are not working. The power supply may need to be replaced but along with it the CPU fan and case exit fan(s).
Mar 28, 2009 | Computers & Internet
Cant get scanner or fax to work in all in one
1st u install the drivers n for fax check ur tel line
Jan 27, 2009 | Sharp AL-1661CS All-In-One Laser Printer
My IDJ2 is unstable
not sure what it can be, but if you used librarian before, be sure that you are running librarian 1.50 with fw 1.09(a). If you have created a library with 1,33, then you have to create the library again with the 1.50 version. Don't use USB powered drives. Mostly they overload the USB port, with al sorts of weird problems. If you have one of these, use an USB powered hub to remove the load of the IDJ2 port. You could test with an USB stick, for a few hours..
regards,
Jack.
Dec 23, 2008 | Numark iDJ2 - DJ iPOD Mixer Docking...
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
Speaker won't work
Sija
First things First:
1) check your connectors back on the PC, I presume you use windows XP and sound drivers installed **
2) plug the speakers cable on back or front of your PC in the green (usually) connector.
3) see if sound is NOT mute on mixer , multimedia in control panel.**
4) If you can Enter your BIOS, try to enable sound, for onboard sound, if apply**
good Luck
Jan 20, 2008 | Audio Players & Recorders
MSI 865G Neo2-PLS Motherboard Logo
104 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
