Question about Minolta Di2510 All-In-One Laser Printer
Hole punching landscape documents
Hi
I need to print out large batches of files - most are in protrait format, but a few are landscape. They should all be collated and holepunched (landscape on the top, portrait left). At the moment, the protrait docs are all coming out as required, but the landscape docs are unpunched.
Can anybody help?
Thanks
  • Minolta Master
  • 6,359 Answers
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
Bought Punch Home & Landscape Design Premium at
The reason of the error 1305 is a bad download or a bad disk
Try to contact Punch TD or try to download your file again
If the problem persists, contact directly with Punch
http://support.encore.com/ the best resources for Punch Software solutions
Punch Software Community Forum
Punchhelpers Website
Learning Punch Software (R): Basic & Advanced Training
Learning Punch Software (R): Importing, Exporting and Printing
Punchhelpers at Faceboo
Aug 13, 2011 | Punch Home & Land Design Nexgen for PC
What software do I need to convert word, jpg and other files to PDF format?
The easiest way I've found is to use CutePDF. It installs itself as a virtual printer, only when you "print" to it, you get a PDF document output. Download it for free here http://www.cutepdf.com/products/cutepdf/writer.asp
Feb 04, 2011 | HP Computers & Internet
My document is in portrait. I've used this same file for over 15 months. Now it is printing in landscape. I am loading the paper the same way I always have.
In your print driver, (start menu, printers and faxes, right click on your printer, select printing prefrences, and select protrait.)
This will set you back to your original portrait print prefrence.
Jan 07, 2011 | Xerox Phaser 7400/DXF Laser Printer
How do you print using the landscape format from the computer?
When you print something look for Properties and set the format to landscape.
If it is a MS Word document set the page to landscape.
If you need further assistance about the setting the landscape format in MS Word or with anything else please leave a comment.
Cheers
Aug 17, 2010 | Ricoh Office Equipment & Supplies
How to print document in landscape
This can be set in the properties of the printer mentioned. you can also request the landscape format in the software you are using. for most printers it is found in the TABS: finishing, paper setup.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
Changing the direction of the paper
when you gave print command the print dialog box there you get properties tab click on that then you will get properties dialog box there you click on layout you will see protrait and landscap.click accordingly.
Apr 03, 2008 | Office Equipment & Supplies
Minolta Di2510 All-In-One Laser Printer Logo
42 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
