Question about Miele S171i Powerhouse Upright Vacuum
I need a complete lower unit for the S171i Powerhouse, Is it available?
    Novelist:
  • 147 Answers
It should be available for purchase. It may not be a stock item but you should contact your local Miele dealer so that they can get a price for you. Miele parts are only available at Miele unfortunately.
Again, check on the price of the housing VS. a new model.
Good luck.
Mark
Posted on Nov 11, 2010
Gear oil change. how much oil
Each gear case has two plugs - an upper, and lower. Take both plugs out and fill from the bottom till lube starts to come out the top plug. Do not fill from the top plug as an air bubble may prevent the case from getting filled completely. Gear lube is usually sold in a squeeze bottle or there's pumps available. If it takes more than one bottle, simply switch bottles, or put your finger over the hole till you get the lower plug back in. In colder climates it's best to change the lube each fall. Inspect the drained lube (old lube) for water. Water will either settle to the bottom and come out first or the lube will have a yellowish color. If there's water present - have the seals checked/replaced before refilling. Sometimes it's simply replacing the seal around the plugs. Do not let water in the lower unit freeze, as it can crack the Aluminum casing. Smaller engines might take a pint, and larger take a quart - but have extra on hand and make sure it comes out the top hole. Also check for drip spots on the floor if stored.
May 27, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
No power
Those have a tendency to short out in the wands. Use a test light or meter to find out where the power stops. Test lower wand first then upper then hose, then unit. Replacement wands are available, there's really no fixing them. I'll include a link to the wands I'm referring to.
Good Luck!
Lower (most common)
http://www.vacuummedic.com/product.php?id=452
Upper (very common)
http://www.vacuummedic.com/product.php?id=450
Feb 12, 2013 | Kenmore 25512/ 25513 Progressive Canister...
No suction?
-Check to make sure the dirt cup is empty.
-Check the filters, If your filters are dirty they can restrict airflow.
The black filters only may be hand washed in cold water with mild detergent, re-install filters when they are completely dry.
-Check for good suction at the end of the upholstery hose. If there is limited suction from the upholstery hose detach the hose from the machine. Insert a broomstick into the hose to push any obstruction through to the opposite end.
-Check the lower hose for clogs. Remove the screw from the left side of the lower hose on the back of the unit and straighten this section of hose by pulling it down or lay unit out flat (the detent will need to be pushed twice) and roll unit on its side with the lower hose towards the top side. Look through the hose for obstructions. Push a broomstick through this lower hose to unclog.
-Check brush belt and replace if broken.
Aug 03, 2010 | Bissell 6594 PowerForce Bagless Upright...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
I have a Miele S1721 Powerhouse upright vacuum. When the belt broke I took it into the shop (because when i tried to replace the belt, the tension was so tight I couldn't get it back together!!). When I...
Hi
The Miele uprights (S170 and upwards) with the Powerhouse title are ALL Panasonic uprights which have been at one time sold in the UK. Therefore the upright may use TWO drive belts which need to be looked at: Take off the sole plate and examine the drive belt which is around the beater bar. Check that this belt is moving easily. Then look at the fly wheel to the motor (usually to the left hand side) and check that the smaller motor belt is moving - it may be broken which is why the beater bar isn't moving and why tension is tight.
Generally NONE of the Miele Powerhouse models have a manual selector for height adjustment - they all use auto adjustment which means no manual selector. The vacuum principle means that general carpet which comes into contact with the brush creates a vacuum anyway between the brush and the floor. If the brush isn't touching the floor then its a possibility dirt or debris has managed to get between the bottom 2 rollers after the beater bar. Check behind the wheels to see that there is nothing there - most auto adjusting Powerhouse models will have a spring behind the wheel and it may have come off.
May 04, 2008 | Vacuums
Beater Bar
Something may have come apart under the nozzle cover, you will have to take the cover off to see. Including a picture, maybe it will help.
Mar 01, 2008 | Miele S184 Powerhouse Bagged Upright...
Miele S171i Powerhouse Upright Vacuum Logo
75 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
