Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I put a new bulb in the tv about 3 months ago. I was watching the tv the other day and turned it off when done. I went to turn it back on the other day and it does nothing, no red, green, yellow blinking lights period. Took the power cable from my monster power center and plugged into wall....still nothing just dead it seems? power supply? just cant figure it out this time
  • 335 Answers
Try pushing in the reset button on the front panel, its very small and you will need a pin to push it in. Do this while the TV is plugged in, then power it on again see what it does. If still nothing then the FMT board is developing a known fault. You will need to replace the FMT board if reset doesn't work....
Also..
It could be a fan issue, if one of the fans in the TV stop working this will cause the TV not to power up too.
Let me know what you find...
http://tvtechwork.webs.com/
Posted on Nov 10, 2010
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
When the TV first went out there was no picture or sound so I replaced the bulb and had sound and pic for about 6 hrs total between 2 days of watching the TV. So I sent that bulb back and received an...
This tv have a board call the ballast board to help the projection lamp to ignite.U hear clicking noises mean the ballast board is dead,not doing it job igniting the projection lamp.
Jan 17, 2011 | Mitsubishi WD-57733 57" HDTV
I have a sony Wega KDF 46e2000 and a couple of months a go it started going off and on by itself. And the local repair shop said we needed a new bulb it was going bad. So we bought one a month ago and I...
Three blinks is a lamp cover error. Make sure the lamp cover is back on securely and try again, there is a switch that does not allow the TV to turn on unless the lamp cover is on correctly.
If this does not work, then it means the lamp cover switch was damaged when you were putting the new bulb in and you need to get the switch repaired or get a new switch. They are two of them and cost about $15 each.
Oct 10, 2009 | LG 42LC2D 42 in. LCD HDTV
T.v turns off about 3 times a day
Its problem of bulb that got weak in result and causing TV shut down.
Replace bulb in TV and I would recommend to buy Sony original bulb for TV safety.
Jul 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDF-E55A20 shuts off for 30 seconds, then comes back on for 30 more
Do just as the others said pull out the bulb and clen the screens on top and bottom of bulb. BUT you can also prevent this from happening as soon the next time. You need to take off the back of your sony tv. On the right rear as you are looking at it there is a black blower on top that is on top of where your bulb fits in. you need a ninety degree phillups head screw driver. take the driver and take out the 3 screws... use a can of air to clean it out... You would not believe the holy hell dust stuck up in that blower!!!! Like I said, take the back of your tv off. If you are not sure where the bulb is once you get it off just turn it on. It's not going to hurt ya. If you are lazy about taking the blower off you can turn it on and shoot the can of air while the bulb is on but you are going to have to take the bulb out ALOT of times to get the dust out of the screens over and over until no more dust collects
Oct 26, 2007 | Sony KDF-E55A20 55 in. LCD Television
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
