Question about Mitsubishi WD62628 62" Projection HDTV
I have a Mitsubishi WD-62628 (older) TV. It is basically a 1st generation HDMI capable TV. My new AV receiver outputs an HDMI signal that is HDCP compliant. The TV will not display video via HDMI (audio works fine, though). Is my TV not HDCP compliant? If so, is there a workaround to display HDMI video?
sandrew
  • 2961 Answers
SOURCE: Mitsubishi DVI input does not work
DVI input only supports 720p, so if you have your settings at 1080i or 1080p in your cable box or dvd player, it won't show a picture.
Posted on Oct 21, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
IrishDruid
  • 2712 Answers
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Posted on Oct 06, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: PS3 not recognized by Mitsubishi WD=52525 tv through HDMI
FYI,
PS3 has output settings and would need to be adjusted if you are coming from the RCA input. Check out www.sony.com/ps3 trouble shooting under display problems. I believe the solution is to turn on the PS3 unit and keep holding the I/O button for more than 5 seconds. I had the same issue going the other way.
Good Luck.
Posted on Jan 10, 2009
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
How do I convert hdmi to RCA composite?
that outputs HDCP hdmi. you probably cannot convert it on a sony. they use software DRM on the hdmi output. Vivid AV HDMI to Component RGB Audio Video Converter
This supposedly talks to the HDCP on sony. Your mileage may vary.
Jan 26, 2015 | Mitsubishi WS-73909 73" Rear Projection...
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
Hi, I have a Samsung LED Smart TV Series 8. However, I can't for the life of me find an AV out so that I can connect my Cocoon AV sender (uses composite cables) to it. Do you know how I might connect...
Sorry , since your TV does not have any A/V analog output you must buy one of the HDMI converter box from an electronic store...and than do whatever you want..
pls visit the URL below as an example..eBay is the cheapest on the market as well.
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
HDMI to Composite /S-Video Converter HDCP analog AV RCA....US $42.96http://cgi.ebay.com/HDMI-Composite-S-Video-Converter-HDCP-analog-AV-RCA-/120741847360?pt=LH_DefaultDomain_0&hash=item1c1cc66140
Jul 09, 2011 | Televison & Video
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
Jan 08, 2011 | Televison & Video
The tv reflects that it is showing in 480i whent he cable is at 1080i. i am using a hdmi cable, i know the tv is plug and play, but if that is not working can i manually switcht the tv to 1080.
There are several solution you can try. Go to your menu and manually set the TV to your own personal setting is the easiest step. The other is to change the source that generate the 1080 res. The HDTV is only capable of producing the signal it receives, not the other way around. If you have a reliable and true 1080 source, then your tuner is having some other issue or the HDMI port is bad. Try using the 5 component YCB plus sound to duplicate the problem. The Component port is capable of producing up to 1080i source. Let me know how this turn out.
Oct 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Have hdcp error flashing on front display
HDCP is copyright protection for HDMI ensuring that you can't copy the protected material.
Did you connect some new DVD player or new TV to the receiver? However the error should clear once you disconnect everything from HDMI. If not, try to restore the receiver to factory defaults.
Apr 11, 2009 | Yamaha RX-V461 AV Receiver
Mitsubishi WD62628 62" Projection HDTV Logo
145 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
