SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
SOURCE: no sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
SOURCE: compatibility ps3 lg rz32lz50 tv
Sounds like your DVI converter. DVI provides picture only, no sound. If your TV has an digital optical input socket, it's best to connect PS3 to TV using this, then digital stereo sound should be yours..
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
SOURCE: Unable to display HD device (PS3) on HDMI screen
Press the INPUT button on the remote or TV control panel until you find HDMI.
When you turn on the PS3 keep your finger on the power pad until an HDMI message apears on the screen.
This should FixYa.
Let me know and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
