Having difficulty adjusting the time. Please explain procedures to set the correct time.
    Scholar:
  • 143 Answers
Hey ,
If your account does't have administrative previlages you can't change time and data.
For changing the time
1: Logon to administrative previlaged account
2: start > run > type "cmd" enter > type " time " enter
Now system will display current time and press enter then i will ask for time change .Now you can change the time if you want
Same the case of date
Thanks
Posted on Nov 10, 2010
Having difficulty with the blade tracking
Please read this blog : http://bandsawblog.com/band-saw-tracking-procedures/
I believe this will help you. Check if the blade is correctly installed and tensioned . Do you have
a good blade? It might be also blade issue. I got Haltbar blades of sawblade.com , no issue at all. Worn out tires can
also mess up the tracking. Please also check the coplanarity of the wheels.
Jan 17, 2013 | Saws
I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
HELLO.
Setting your microwave clock is explained below.
It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be put off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Is there anyway of transferring pictures from internal memory direct to the PC? I am having difficulty in transferring the photos. Please help..
The correct procedure is to go into the menu and find "copy". You will find the option to copy the internal menu to a memory card.
Apr 02, 2011 | Panasonic Lumix DMC-FZ8 Digital Camera
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
Hi please explain how to set correct time on
According to the manual:
The easiest way to set the time is by tapping the Sync button. Your ONE XL will then take the time from the GPS information it receives.
Hope this is helpful.
May 01, 2010 | Tomtom ONE XL GPS
Timing belt , ''eccentric tensioner bearing'' adjust on 98 magna v6
I can tell you the whole procedure. If you would like it please contact me. It would take me awhile to explain the whole procedure on here.
Aug 01, 2009 | 1998 Mitsubishi Galant
Canon Flatbed scanner model D646U ex for Windows XP
Could be a problem with the cables themselves. Try a new set or different set of cables and see if this resolves the issue. Also make sure that you installed the correct version of the driver for your OS.
Should you still have difficulties, try a clean boot as explained below:
http://www.fixya.com/support/r545614-installation_problems_clean_boot_install
(Just replace "camera" in the procedure for scanner.)
May 15, 2008 | Canon CanoScan D646U Flatbed Scanner
Difficulty in first time support with zoomX6 5590
Hi Maybe i could help you. I have installed this modem before for an ISP provider. Please give me specific task you want to do and I will explain what to do.
Apr 30, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Computers & Internet Logo
160 people viewed this question
Alun Cox
David Payne
David Payne
