Question about Vacuums
I have lost my manual for Nexxtech thermometer model6312030. I can't get it to read the outside temperature after I changed the batteries. How do I reset to make it read. Or better yet, how can I get a copy of the manual?
The problem here was solved but replacing weak batteries in the main unit and pressing reset on the main unit
It took a minute or two for the temps to update
Posted on Mar 31, 2014
You must reset the outside unit every time you change a battery. To rest insert a paperclip into the small whole marked "reset". Temperatures should now appear on the inside or remote unit.
St. Bruno, Quebec
Posted on Dec 18, 2010
  • kdl16 Aug 30, 2011
    The outdoor temp just keeps flashing even after I reset
  • Jessika Rose Mar 06, 2012
    I have the same problem, we tried to reset it on every channel, and the indoor display reads --.-
    If you figure it out please post it to let me know! Thank you.
Has the battery got a fuse link in it?
If you don't get any voltage reading across the + and - terminals, the battery is faulty. The aux terminals are used to sense battery temperature and charge state. You most likely have a bad battery.
Mar 05, 2016 | Filter Vacuums
Dyson dc 35 troubleshooting
Battery low, Temperature too low, Filter clogged Read the manual - page 5 and check the light on top of handle
Oct 07, 2014 | Dyson DC35 Handheld Vacuum
The remote sensor on my wireless thermo Te279NW does not record temp on inside unit
Check batteries in remote sensor and if OK try moving the sensor closer to the inside unit. Any kind of RF interference will limit the range including flourescent lighting.
Sep 07, 2011 | NexxTech Vacuums
I have an Equity Weather Station model 31215B and i was wondering if the outside wireless thermometer is waterproof .
The wireless unit that transmits to the indoor unit is weather resistant, but not immersible. Even so, try to shield the transmitter from the sun and rain, if possible. When positioning the transmitter, keep in mind that direct sunlight may cause false readings and mounting it on heat-retaining materials (like brick) will show a higher temperature, even after sunset. Avoid mounting it anywhere near things that give off heat (air conditioner units, dark exterior walls, etc.).
LaCrosse has not yet uploaded the manual for this, but you may check later at:
equitybylacrosse.com/31215
Good luck from Detroit, MI.
Apr 29, 2011 | Vacuums
I cant get my weber remote thermometer to read the temp.
Note: both the transmitter and receiver unit have a re-set button under the battery compartment lid. If the receiver is not receiving a signal from the transmitter, you will need to disconnect the probe and re-set both units while 'on' before re-connecting the probe.
This is straight off the weber website, and it works coz mine just started reading temp
Jan 08, 2011 | Vacuums
How do you set the time on the nexxtech am/fm alarm clock with cd player model no.1219568?
Hold the Timer button then press the Hour / Minute buttons to set the time.
Dec 30, 2010 | NexxTech Vacuums
How do i set up my westclox 70034 outdoor thermometer to read on my clock unit.
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 16, 2010 | Vacuums
How do i set the thermo sensor 433mhz to my westclox 70034 model
Oct 11, 2010 | Vacuums
I changed the batteries in my window thermometer (the one with suction cups) and it is still giving me the change battery alert.
Remove the batteries and using an emory board or fine sandpaper scratch up the metal pieces where the battery ends make contact inside the unit. It could be that the metal pieces have corroded a bit and need to be cleaned to make proper contact with the batteries.
Oct 08, 2010 | Vacuums
Vacuums Logo
540 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
