Question about Sharp AR-M160 Laser Printer
F2-66 code on Sharp MX3501N. This is an emergency. We NEED to print Proposals for potential clients here and our suppliers are not showing up fast enough. This is the second time in a week, we have been serviced for this a few days ago and the code is back once again. How do I fix this myself ?????
2 Suggested Answers
pin_0018
  • 77 Answers
SOURCE: Call for service
There is a problem with the Bk Toner supply.... check the End Seal was removed on the Cart, if not that, then call a Tech.
OR
put the an old, used bk toner cartridge back in and restarted the printer. Once all the codes cleared, removed the old bk toner and put back the original bk toner u had removed.
that should fix
Posted on May 13, 2009
Error code h3-02 SHARP MX3501N
fuser temp is exceeds specified level-your firmware needs to be updated.
Mar 22, 2017 | Sharp Mx-3501n Copier Color Mx3501n...
What is error code FK3 on Sharp MX3501N
FK3 is the code for the cleaning web in the Fusing Unit.
Jul 30, 2012 | Sharp MX-2300N Color Copier
We have a sharp mx3501n printer. Whenever I print from Photoshop CS2 the prints are horrible. Any suggestions for color profiles/settings that might make this better. Should I be using a CMYK file in...
Definately CMYK so you can see which colors are out of gamut. If copies are lousy too, then you might have old supplies in the machine. In service sim mode (type # * C *) go to 64-5 and print the test charts directly from the print engine. You should get one greyscale and one color page. If those look bad, then you need a supply change (drum, developer, or belts). In the driver under Printing preferences you have the option to set color schemes until you find one that works. If you still have trouble, get a new driver from www.sharpusa.com, past that a firmware flash may be necessary.
Jan 25, 2011 | Sharp MX-3501N All-In-One Printer
Im using sharp copier degital. now it show me only H and then 2 what should i solve my problem?
Hello
the code is H2 to clear it make this:
enter the simulation mode: press # key - interrupt key- 'C' key - interrupt key then enter 14 and pess start print key
note : make the entering fast
good luck
Dec 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to connect a sharp printer mx3501N to a network
the best way is to hook up the copier to the closet router set the machine to dhcp let it assign a ip address and install drivers, etc...
Nov 04, 2009 | Sharp MX-3501N All-In-One Printer
Machine has been off for 6 months. Plugged it
If you mean the LCD is only partly showing, it should be replaced. Just sent in two for the same problem with clients. Apparently, supplier switched to cheaper parts, causing this. Should be under warrantee. Call fast. If you never set up the warrantee, you should do that first. I'm "SURE" you bought it less than 3 years ago...Right???? (Hint) 800-989-2299
Sep 21, 2009 | Ecoquest Fresh Air Air Purifier
Call for service
OR
that should fix
May 13, 2009 | Sharp MX-3501N All-In-One Printer
Vertical middle badly printed band
Hello sir; Make sure the glass is clean before you change another new cartridge.
Mar 31, 2009 | Sharp Office Equipment & Supplies
How to scan using a sharp mx3501n?
as long as your machine has been configured within the network settings. press the image send key then addres book then enter your email or select the folder or email addres to send it to.
Dec 02, 2008 | Office Equipment & Supplies
Sharp AR-M160 Laser Printer Logo
967 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
