I need to replace the final and driver transistors for a KLH 765s subwoofer.
  • lhyounger Nov 11, 2010
    What I was hoping for was a circuit schematic with part numbers or part informatiom.
    Looking at the circuit board there appears to be two large transistors on the heatsink that look to have been burned ( discoloration on the board. I think these are in a push pull configuration. It looks like there are two smaller transistors feeding these finals, but that is a guess. thes two smaller transistors also show some discoloration. Also do you have an easy way to determine if the speaker coil has shorted. Perhaps a nonimal resistance?
  • 8,197 Answers
Sorry there is no way to replace the drive transistors yourself. You will need to send in to have serviced.
Posted on Dec 07, 2010
  • 2,427 Answers
Well ok..
1.) locate and remove transistor (I guess you know which one is which)
2.) unsolder it,
3.) get replacement (the number of the part is the same one you need avoid substitutes)
4.) re solder it on the board.
Ok By final and driver transistor I'm guessing you meant the 3 pin output IC. Its actually a set of them for each channel has one, Its the largest IC (transistor looking) attached to the heat sinks..
Posted on Nov 11, 2010
  • Rishi Roshan Ali Nov 12, 2010
    actually yes there is a method i use..
    ok this is my personal way, its easy and it works. What I do is work backwards..
    you need a multimeter..
    FOR SPEAKER COIL..
    connect both leads to speaker connectors,, set the multimeter to 20 k resistance
    "gently" push up and down on speaker,, you shoulc see the multimeter move.. If not well speaker coils dead..
    Concerning your board..
    The two large transistors are the ones you need to replace ,, yes there can be other parts damaged as well,, what you do is take your multimeter and tracer the circuit from the burned up transistor all the way back until you find an unburnt part, connect your ground there and set the multimeter to Diode or (beep) now use the positive lead and work your way back touching each component along the circuit to make sure its fine,, If you got a beep its good, if no beep then change him..
    Normally a capacitor goes with the output IC or sometimes only the IC, If you dont see a cap leaking oil or burnt (right around the IC) then just change the IC.. the two small transistors are more than likely switches I dont think there burnt but test them and see..
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
I have a KLH subwoofer which is connected to my reciever and speakers with speaker wire. It is not connected to an outlet. It has recently started making a buzzing/rattling type sound. Do I need to take...
Yes, probably, if you aren't capable of repair yourself. However, IMHO, a replacement will probably cost less in the long run. I have a KLH passive subwoofer myself. I wouldn't pay for any repair if it failed. Replacements are far too inexpensive.
Aug 18, 2014 | KLH Audio Players & Recorders
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Nov 13, 2010 | KLH ASW10-120 Subwoofer
KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Dec 26, 2009 | KLH ASW10-120 Subwoofer
Hum no audio output
There are a lot of folks who've had power supply issues with this sub. Typically, the large resistors fail, which takes out the capacitors.
If you know how to read schematics and replace parts, then these might be helpful to you:
Here are the two pages of schematics from KLH. I wrote to their tech department and explicitly asked for permission to share them here.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
Dec 22, 2009 | KLH ASW10-120 Subwoofer
My speaker just rip.. i like to know any subwoofer is ok for replace??
it's an 8 ohm driver. It need to be VERY efficient, around 90-91db @ 1w. Measure the enclosure size LxWxH then divide by 1728. That will give you your cu. ft. internal airspace of the box. Then look for a driver that will effectively work in that space. Shouldn't be too expensive, paper cone, foam surround, 8ohm impedance. Hope this helps
Dec 12, 2009 | KLH ASW10-120 Subwoofer
No sound and smells like burning
Here are the two pages of schematics from KLH. I wrote to their techdepartment and explicitly asked for permission to share them here.
Nov 08, 2009 | KLH ASW10-120 Subwoofer
Burns [blows out the 50v bridge rect] on power up. cant find the short??? all conds and resistors seem to check out OK ??? The four Z-diodes seem ok also ??? All transistors seem ok [no low ohms-only...
I'd suspect the 6800uF caps, but I don't know for sure.
If it helps, here are the schematics for the upper and lower boards:
Upper board
Lower board
I wrote to KLH to ask for them, and explicitly asked for permission to post them here.
Jun 15, 2009 | KLH ASW10-120 Subwoofer
49 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
