Question about Dell Computers & Internet
Hello guys!! I have one of the old Dell 1525s, and my HP laptop just died, so I've had to resort to (ugh!) using it!! HOW ON EARTH IS IT POSSIBLE TO RESTART THE DELL 1525 JUST AS IF I JUST BOUGHT IT FROM THE FACTORY? THERE IS A WHOLE BUNCH OF OLD STUFF ON IT, AND I DON'T EVEN KNOW HOW TO GET RID OF IT, AND I DON''T EVEN HAVE THE ORIGINAL DISCS ANYMORE!! MOST LAPTOPS JUST HAVE SOME KEY COMBINATION TO START IT AS IF YOU'RE STARTING FRESH!! THANK YOU ALL SO MUCH!! daniel.bush5@gmail.com
  • 15 Answers
Hi
if you havent reinstalled windows on that computer yet try this:
for XP
press CTRL + F12 after pressing the power button to restore sys to dell factory image.
for vista
press F8 after pressing the power button to go into advanced boot options
press enter on repair my computer
press enter on pc restore.
it sets your computer back to factory image.
Posted on Nov 10, 2010
  • PJBHOi
    PJBHOi Nov 10, 2010
    sorry, for XP it CTRL F11 my bad..
Have 2 dell inspiron 1525s, can I use the hdd from one in the other without having to reformat the good hdd
Swapping hard drives from one computer do not work because of hardware differences even between same brands and models.
You can install Windows XP on his computer but you need the Windows XP installation CD and you will need to use the product installation code from your computer. It is printed on the Windows label that is attached to the bottom of your laptop.
Mar 21, 2013 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1545 has stopped printing
first check the printer cable
then try to uninstall the printer driver
restart the laptop
try to install the driver again
print the test page
Feb 06, 2013 | Dell Inspiron Computers & Internet
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
My Dell M70 screen flashes on and off and i have to turn laptop off and restart.
Try a lower resolution like 800X600 to see if it stops. If it does not, the possible issue is the connection between the laptop and the screen. I've had to replace screens for this issue as a last resort and fixes it.
Oct 31, 2012 | Dell Computers & Internet
Hello guys. I need help with my hp dv4 1225dx pavilion. It all started with not powering with battery power. But the battery is in perfect condition. When I plug in the power cord. It comes on and I...
It sounds like a hardware issue, if you're getting the LED's blinking when pressing power, there IS power to your mainboard (which is a good thing). Some manufacturers have placed LED blink codes within the system to let you know what's going on, but I have a feeling it's either A) your battery or B) your hardware, such as a bad RAM stick.
Try removing the battery and with the power plug connected switch the laptop on. If it works, you've got a bad battery.
Try removing a single RAM stick or replacing both.
You could search HP Pavilion LED blink codes to further address the issue.
Jul 18, 2012 | Computers & Internet
HOW TO REMOVE SCREEN FROM DELL VOSTRO 1000 AND CONNECT TO A MONITOR
if laptop is still running with a broken LCD screen , it id possible to use an external monitor, if laptop totally died or broken, not possible to use with external monitor.
Mar 26, 2012 | Dell Computers & Internet
Display on but back light not on HP nx 6110
This could be an issue with the inverter problem. Are you using a universal adapter? If so, this could be the possible reason why the inverter died. It is not supplying the correct input for the inverter, thus the damage.
Please consider to bring this to an authorized HP service center. If its still under warranty, the better.
Aug 12, 2009 | HP Compaq nx6110 PC Laptop
External Hard drive = possible shortage???
I have found that after all the new updates the system takes on. It becomes less an less likely to even recon ise old equipment. This one way the big guys phase out our old stuff.But you should be able plig in external drive , in a usb port . like a 40 gig for about $70.00 at raido shack, and they will stear you in the right direction. thoes guy know there stuff
Apr 11, 2009 | HP/Seagate 3.5inch 450MB IDE Hard Drive...
Hello My laptop has died and i need to transfer everything on my hard drive to my new laptop. Is this an easy task and is it possible. Please HELP !!! Thanks Chris
hi thanks for using fixya!
what happened to your old laptop? you cannot turn on anymore your old laptop? I suggest that you bring your laptop to a service center so that they can open it, and remove the hard disk from the old laptop then they can connect it by using USB cable then, you may copy your files to your new laptop!
If you need further assistance, let me know!
Pls rate me positively! thanks!
Mar 29, 2009 | HP Computers & Internet
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
