Question about Fisher and Paykel Dishwashers
My model # is 88270 ukm750601...serial# fp dd603 ss usa The drawer on top is difficult to open and power won't come on. The bottom drawer works fine.
  • 3,230 Answers
Well if you tried to turn the power off from the mains and back on, in most of the cases it works. If that does not release the drawer then the lid seal has locked up. Turn off power to the dishwasher and take the bottom drawer out from its housing carefully without tugging the hoses at the back. This will expose the power module at the base. This supplies the power to the lid seal actuator motors on both drawers. After then you try to disconnect the leads going to top drawer and turn power back on. This should free up the lid seal (might need a little pull to get drawer to open). Connect everything back in (disconnect power first) and then check again if it works.
Good Luck!!
Thanks
Posted on Nov 10, 2010
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Fisher paykel dishwasher dd603 won"t turn on.
Is the problem with both the drawers or just one.
When you say - will not turn on - does it mean you get a blank display?
assuming mains power is turned on (no problem with circuit breaker), then it is likely the power board at the base of dishwasher (under the bottom drawer) is faulty and needs replacement. Make sure mains power cable is taken out when you work on the dishwasher.
Dec 11, 2012 | Fisher and Paykel 23 in. DD603H SS...
F&P dishwasher (DD603i) has no power to top drawer
No power to the top drawer needs to be verified.
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Depending on your familiarity with such equipment you could try to replace and fix. I am not quite sure what the new model you mention is. I believe all DD603 models have power to the 2 drawers coming from the base board.
Feb 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Model DD603 top drawer has no power and is difficult to open/shut....Help!!
No power to top drawer,.... sounds like the main pcb is shot.... and happened when the washer was in use, so the lid assembly is clamped down, you can still open it by pulling but has alot of resistance. easy to replace the PCB, but dear to buy it!...
Nov 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
No power to top drawer so I cant even run a
If the controller is faulty then you will not see any life in the drawer unit. The controller is mounted on the front of the unit behind the door panel.
Oct 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Need Fisher Paykel DD603 SS-USA repair manual
Downloaded operator manual from fisherpaykel.com. This is not the repair manual I sought.
I was able to fix problem of top lid not clearing drawer by removing drawer, lubricating rubber gaskets, slides, and hoses with Armor All, then reassembling and cycling the timer at 12 minutes.
The lid then opened fully and did not hang up.
Mar 02, 2009 | Fisher Dishwashers
Top drawer stuck, gaskets rubbing, no power to controls
I see the question is posted in the DD603 section, so I am not sure if I am giving the proper advice. Are you sure this is a 602/601 series? A DD603 model has lid actuator motors, not the inflatable style seal. It sounds like the lid motors are in the DOWN position. Since the machine is "dead" what may have happened is the heater plate opened up (the heater plate is a dropping resistor inline with the machine's controller) when the machine was in use and that stopped everything dead.
Double-check your model number so we know what style of lid your machine has, The difference is huge between models.
Dec 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
70 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
