Question about Kenmore HE2 Plus Front Load Washer
The washer stops during the washing cycle and flashes F21 error. Can't open the door.
  • Kenmore Master
  • 8,220 Answers
F21 Long drain
Possible cause: Clogged filter, clogged/failed pump
The washer stops during the - themobilian_84.jpgthemobilian_85.jpgthemobilian_86.jpg
Posted on Nov 10, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
I think Ihave a wfw 9200, the door lock light is flashing and cannot be cancelled. There is a f21 fault code flashing. HOW can I open the door ?
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time.
As for the door locked issue, it is a by-product of the F21 error. Make sure you get the water out before attempting to open the door manually or it could be messy.
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼" or until a click is heard.
6. The door may now be opened.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance and leave a brief testimony.
Regards,
Macmarkus :)
May 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
Washer was flashing suds code followed by F21 code. I was able to use the drain & spin setting but now it won't open or reset even when I uplug the machine it just keeps flashing the minuets to...
Hi, "F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. This LINK explains.
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
If you need to open the door but it remains locked, you can first attempt to unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). If the door remains locked, you can use the manual release to unlock and open the door. The LINK explains how.
NOTE: The Maytag Epic is manufactured by Whirlpool, so these procedures will apply to your washer.
Sep 13, 2010 | Maytag MAH8700A Front Load Washer
My washer stopped and was flashing F21 (drainage issue) so I called a plumber. He checked the hoses and removed the panel and cleaned the drain trap. It didn't fix the problem it's still won't drain. It...
The SUD message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked. this seems to be the reason as to why your unit is not fixed even after trying to solve F21......
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Good luck
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door is locked code F21 wont run or cycle or empty water
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Jan 13, 2010 | Kenmore HE2 Plus Front Load Washer
The door to the washer is locked and it won't unlock and it says F21. it is flashing. it just stopped mid cycle. What do I do?
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If you need to open the door but it remains locked, you can first attempt to unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). If the door remains locked, you can use the manual release to unlock and open the door. The following link explains how: http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed If you have any questions about these procedures, or need additional assistance, please let me know. I hope this helps you. NOTE: The Maytag Epic is manufactured by Whirlpool, so these procedures will apply to your washer.
Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer won't stop beeping and can not change cycle selections
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
306 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
