Question about Asko XXL UltraCare WL6511XXLPP Platinum Washer
Washing machine shakes like crazy especially when
Washing machine shakes like crazy especially when it is in spin cycle. it moves so much it moves from the spot where it was.
4 Suggested Answers
Timon90
  • 126 Answers
SOURCE: noise
The squeking may be caused by the 'V'ring casette that enclosures the bearings. Have seen some episodes with that. It's very much work to remove the drum, so dont do it if it's not is absolutely nessesary!
Posted on Jan 23, 2008
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
heatman101
  • 43501 Answers
SOURCE: My washing machine will not spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 25, 2010
When the machine is on spin the machine shake so bad that it jumps
If the drum has an unbalanced load any machine will shake like crazy during high speed spin cycle - some even have a buzzer and shut down! Rearrange the clothing in the drum.
Oct 28, 2015 | Washing Machines
WTW4800xq0 shake bad during spin cycle
My washer was just doing the same thing shaking like crazy on spinning cycle whirlpool model WTW4800xq0 I just change the 4 suspension spring balancer rods part #W10820048 and it work like new againg search amazon cheaper than sears easy to change I hope this help some body and save money this parts cost $50 dollars on amazon
Dec 01, 2012 | Whirlpool Washing Machines
My washer makes a horrible noise in the final spin cycle on all washes
does ur washer shake & move also? if so, it may be that the loads r too small. especially with top loaders, when the machines not full, the clothes r not evenly distributed and that could do it. if u stop the cycle and evenly distribute the clothes, it should stop. hope that helps.
Jan 10, 2012 | Whirlpool Washing Machines
Estate washer bangs and shakes like crazy in spin cycle after being moved from one house to another.
has it been releveled? if it has then it sounds like there is a problem with the counter weight or suporting springs/bracket the only way to tell is to check inside the machine.
Jul 28, 2011 | Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
New washing machine
FIRST CHECK SECURING BOLTS HAVE BEING REMOVED IF SO THE PROBLEM IS YOUR MACHINE IS OFF BALANCE TO RECTIFY SET WITH SPIRT LEVEL.
Oct 18, 2009 | Washing Machines
Shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Jul 01, 2009 | Washing Machines
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Asko XXL UltraCare WL6511XXLPP Platinum Washer Logo
32 people viewed this question
Top Asko Washing Machines Experts
Marvin
Marvin
Sal De
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
