Question about Whirlpool Water Heaters
Pilot lite went out and after many attmepts it ignited. Had the thermalcoupe replace just in case that was it. Stayed lit for 2 days now it is out again and will not stay lit. Bloggers are suggesting a factory defect in the gas valve. What do you think? Model #FGIF4034T3NOV Serial# 0325128519
  • Carey Adams Nov 11, 2010
    thanks a million Joe, I will check this out.
  • 10,865 Answers
Hi. Before you go to the expense of a new gas valve , a correctly adjusted pilot flame is steady and blue, and stands between 1/4 and 1/2 inch high. If the flame goes out repeatedly, it may be getting too little air; if it's yellow at the tip, it's getting too much air. To correct either condition, turn the pilot adjustment screw slightly, as directed by the manufacturer.
Joe
Posted on Nov 10, 2010
Have a new richmond water heater.there was no hotwater.i checked the water heater pilot was not lit.i relight it, it lite.turn to temp settings pilot went out.relit it againmade a explosion bom sound
the explosion was from a build up of gas that was not properly ignited by the pilot light or was leaking into the combustion box when there was no pilot light
there is a serious problem in the gas control system that needs urgent professional assistance to fix
you were lucky as it could have blown you out of the room
get in an experienced gas fitter as it is not a diy job
May 11, 2016 | Water Water Heaters
GAS WATER HEATER PILOT WILL NOT LIT
assuming you mean you have electric ignition, DO NOT try to lite with a flame of any kind. make sure gas is on, while pushing knob turn to PILOT hold knob down for appr. 10 seconds while still holding knob down,push ignter. you may have to do this proccess afew times. if this doesnt work, call a pro. gas appl. can be extremily dangerous
Dec 21, 2012 | Water Heaters
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
Pilot is hard to light and when it does,it will go out when you turn it to the on position it goes out. I took bottom cover off and blew the screen out but still goes out. It looks like it is starving for...
If pilot flame is weak, the burner parts and pilot tube may need to be cleaned.
Other causes can be bad venting, negative air pressure, low gas pressure, air in gas line, bad gas control valve thermostat, damaged burner parts from exposure to chemicals, etc.
Open following links for troubleshoot resources, including service manuals and illustrations:
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 19, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
The pilot went off and will not lite
There is a special procedure for lighting pilots. It should be clearly labeled on the unit. If you are following this and it will not stay lit, then you need to call a certified repair tech.
Feb 14, 2011 | Rheem Water Heaters
Pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Jan 23, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Bosch Aquastar tankless water heater model 1600P Pilot is lit but main burner will not lite. replace water valve that controls ignition.
There should be a thermocoupler, it is that bulb that sits in the pilot flame. If it is not functioning properly the main gas valve will not open.. Hmmm, Is the main valve in the on position?
Oct 10, 2009 | Bosch AquaStar 1600P-LP 1600P Liquid...
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
60 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
