Question about LG Televison & Video
Hi, I have a LG 42LC46 TV which is two & half years old. About ten minutes after switch on the picture statrs to break up and sometimes the screen goes blank. This last for about one hour after which the picture is fine. It has been back to the Teckguy's three time without success. They say they can't replicate the problem. We have set another TV up to the same system with no problems at all. I beleive the Techguy's don't set it up for testing using the HMDI leads. Could the problem be with the HMDI input port on the TV? Many thanks Joe Trotter
  • 208 Answers
SOURCE: Sharp aquos lcd screen goes blank
The problem is most likely the the screws are loose on the inverter boards. The screws must be tighted as they provide the ground to the inverter bds. The inverter boards are undet the shields on both sides of the unit after pulling the back cover. One way to make sure that you are losing back lights and not video is when your picture goes black, shine a flash light on the screen at an angle and will see the video is still there. This mean the back lights are out. If you do not see the video it may be another problem
Posted on Feb 05, 2008
  • 579 Answers
SOURCE: ESA 42 Plasma picture problem
The power supply is having difficulty. The typical cause is underated electrolytic capacitors. I would examine all the caps (round cylindrical cans) in the power supply and see if any of them are bulged. Not a bad idea to just replace all of them with better rated parts.
These type of caps have all kinds of specs. Not just voltage and capacity, but also temperature, case size, and obtuse stuff like dissipation factor. Most all power supplies use switching type designs that run at serious frequencies (not the old 60 hz - more like 50khz) that stress out these electrolytic caps and many circuit designers (or their cheap bosses) don't specify the better parts. Replace them with the same capacitance, but higher voltage, and higher temp parts (hopefully they will not be too big physically).
Ya, I know you paid $$$ for this TV and they scrimped on cheap parts. Yup, the more expensive a product is, the more pressure the bean counters put on keeping the price down.
Hope Ya Fix It.
Posted on Feb 12, 2008
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
SOURCE: westinghouse 32 inch screen goes blank
I had the exact same problem and I fixed my Westinghouse 32 inch by replacing the power supply. You can purchase it at
http://www.partstore.com/Part/Westinghouse+Digital+Electroni/Westinghouse+Digital/4900211680/New.aspx?ModelMfgName=Westinghouse+Digital+Electroni&ModelBrandName=Westinghouse+Digital&ModelNumber=LTV32W1
I takes about 15 minutest to replace. Just take the back lower panel off and replace the power supply. Mine works like new now.
Posted on Jan 25, 2009
  • 80 Answers
SOURCE: Screen lower half goes black/blank
The lower "Y Buffer" board is defective. Best repaired by a technician, or contact Phillips support for the part if you think you are able to replace a small circuit board on your own.
Posted on May 21, 2009
42lc46 zc
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 26, 2014 | LG Televison & Video
LG 42LC46 ZC AECVLJG about 6 years old, we r having trouble switching it on. There is no red light on or sometimes it flashes on and off, usually it has been a good set. we r with sky and HD, ca
The most likely cause of this problem is the power board.
Take the cover off, make two-three good high-resolution up-close shots from different angles and send them so we can tell you if there are visible issues with it.
For more detailed troubleshooting you'll need a voltemeter and tons of patience.
http://www.coppelltvrepair.com
Oct 15, 2010 | LG Televison & Video
I have a Sony Bravia television that is about 2 and a half years old. For about a year, each time I would turn the television on the picture would be split down the middle with one half of the picture...
you know sony is good brand name now people not trust sony because all made by koria same factory in samsung so some thing manufacture problem sony iso lot of complaint lcd tv panel are very less life time ony panasonic viera ips alpha panel is my opinion good becuse made by japan
Sep 08, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Vertical lines on LG 50PB2DR
You need to replace the control board
May 22, 2009 | LG 50PX1D 50 in. Plasma Television
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
98 people viewed this question
Computer Repairing
Computer Repairing
