Question about Honeywell Aube by TI0323W5U 7Day Programmable Timer Switch Almond
Hi i lost the instructions and don't know how to set the clock. please give me step by step once i reset the unit.
You posed under Aube T-1032 7-day programmable.
Aube makes a list of timers and each timer has different instructions.
For your convenience, I posted the Aube timers and manuals :
http://waterheatertimer.org/Aube-timers.html
I answer questions for free.
I am more than happy to write out the long list of instructions from the manual.
But the instructions apply only to the T1032.
They don't apply to the T-1034, T-1035, T-1052, T-1054, T-1070, T-1073.
If you would like me to write out instructions for one of the other timers, add a comment and tell me which timer.
T-1032 Manual
Set current time on T-1032:
Press and hold reset button
Display should be visible
Press Hour button to set current hour with AM or PM
Press MIN button to set current minutes
Press DAY button until current day shows (for example TU for Tuesday)
Close cover and press cover to confirm times
Programming overview:
Make a chart of your programs before starting to avoid conflicts in programming.
You can set 7 different programs
Program1 program2 program3 through program7
Each program has ON and OFF
First you set program1 ON with times and days of operation
And then you set program1 OFF with times and days of operation
Programming:
a) program1 ON
Press PGM button until the display appears as below:
P1 ON means you are ready to set program1 ON
Press the Day button to select days of operation for program1 ON
Press Hour to set hour am or pm for program1 ON
Press MIN to set minute for program1 ON
b) program1 OFF
Press PGM button until display shows: P1 OFF
The display will also show the the same Days you selected for program1 ON
Press Hour to set hour am or pm for program1 OFF
Press MIN to set minute for program1 OFF
c) To set program2, press PGM button until P2 ON displays
Repeat steps above to set all 7 programs.
d) To finish programming, close cover and push in cover
e) Select operating Mode.
Press and hold the cover until AUTO displays.
f) Press in cover for manual override.
Posted on Nov 11, 2010
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Need instructions on 'programming' my Sharp SPC900 Atomic Clock. It has lost sync with the satellite and didn't automatically catch up with DST.
I don't know about your atomic sync problem. But here is how you can set the time zone:
Push the Time button once. This will change the Month/Day window to Alarm 1. Push the up button until the desired time zone is reached. Push the Time button twice more to return back to Month/Day display.
Mar 15, 2010 | SkyScan 86709 Atomic Wall Clock
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
Sony radio/cd/clock under the cabinet. Lost
On the right side there is a push button switch labeled "Clock". It is springloaded so you have to push it in and hold it for a couple of seconds until the unit beeps and the hour position starts to blink. The volumn up and down buttons will control the changing of the numbers up and down and PM/AM. Pushing the clock button again will change the clock to the minutes position and you cann adjust the numbers up or down just like the hours. Push it one more time will lock-in the new time. Your done.
Jul 20, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
Don't know how to set the clock
For most Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Apr 23, 2009 | Pioneer DEH-P2900MP CD Receiver...
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sanyo Microwave Ovens
How to set the clock
Hi There
you will need to hold down the source button till the unit shuts off
once the unit is off look for a Button with a F (Function) hold this button down till the LCD display turns on it should only take a few seconds.
once the F (Function is active on LCD) press the F Button (i think its X2) till you see the clock
once your are at the flashing clock use the skip buttons on unit to switch numbers after the hr time is set press F Button again to adjust the minutes.............
when this is done press the source button to turn the unit back on and the clock should be set.....
hope this helped
Mar 05, 2009 | Pioneer DEH-P4700MP CD Player
Lost instructions for bubble console pre school game
hi tim im having some problems with bubble at the moment its unreal i have some phillips codes dont know if they will work however ill give them to you anyway
0503 0539 0646 0671 0675 0854 0885 1158 1260 1267 1812 1813 1818 1911 1914 if you stick the set up dvd in n watch the first time set up bit it explains everythin you need to know i there hope this helps you out!
Dec 20, 2008 | Toys
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
Need operating instruction
I dont know where to find an instructions booklet but I can help with setting the time/date:
To set the time and date (you have to do them both together):
  • First press and hold the 'CLOCK' button until it beeps then let go.
  • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
  • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
  • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • You will need to repeat this to select the date (day).
  • You then use this same process to select the time, starting with the hour and then the minute.
  • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
Mar 16, 2008 | Sony ICF-C273 Clock Radio
Honeywell Aube by  TI0323W5U 7Day Programmable Timer Switch Almond Logo
326 people viewed this question
Top Honeywell Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Honeywell Hardware and Accessory Expert? Answer questions, earn points and help others
