Question about RCA Televison & Video
I have an RCA L32WD12YX7 flat screen tv. When I turn it on, the on/off light switches from red to green, then back to red ... etc. After it does this a couple of times, it settles on green, and then is ok. What is the problem?
  • RCA Master
  • 19,396 Answers
Hi.
Unless there is a determined flashing pattern, the light switching from red to green, then back to red, indicatest simply that there is an internal fault; that the incorrect voltage has been detected, and that the TV has been forced to stand by to prevent further damage.
After you click several times the TV turnson: This is common. Depending on what component is damaged, the TV may overcome the problem once a determined circuit has fully discharged; when a circuit is fully charged and stabilized, or even erratically because of a bad soldering joint or wiring.
This kind of problem is commonly caused by PSU or inverter. This parts use big charge reservoirs (the capacitors) to store charge. When one of the capacitors is faulty, the other parts in the circuit can compensate for a certain time the problem, allowing startup. The problem will get worsening in time as components in circuit will go will start blowing soon. The result will be a TV staying in forced standby and not starting.
Parts must however be tested before replacement. Even if PSU is more common problem, there are more parts that may need testing. In this particular model SMPS must also be tested.
If power supply stages are OK, testing will follow on digital board, inverter and other parts.
Since the TV is occasionally starting, voltages may be OK. Testing will start at component level in this case.
Repair must be done by a trained technician.
If you need to contact a technician, or if you want to verify warranty status, please contact the RCA phone number listed in the user manual.
Here parts for this TV
See also Contact - RCA Television
Posted on Nov 10, 2010
How do I check led strips on my rca flat screen tv? and/or how do i replace the led strips?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 18, 2015 | RCA Televison & Video
Rca tv L46WD22 and green light followed by 5 red flashing lights
These blinks (Flashes) are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check these link s
http://electro-medical.blogspot.com/
Dec 13, 2013 | RCA L46WD22 Television
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
My RCA 42" HD flat
sounds like it needs new caps on the power supply board..............easy fix if you can use a soldering iron........
cheers
Apr 07, 2011 | RCA L42WD22 42 in. LCD Television
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
Televison & Video Logo
394 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
