Question about Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ
Whirlpool ARC 5070
Hi, Have this whirlpool where the fridge/freezer is not working, only thing that is; is the light that comes on when I open the door, so power is getting to it anyway. Any ideas?
  • 1 more comment
  • Declan33 Jun 18, 2008
    Hi, thanks.
    The light is not even coming on now so no power at all getting to Fridge it seems?
  • Declan33 Jun 19, 2008
    Sorry I should have added, the super cooler button turns on when I press it, so power still getting to Fridge, Called Whirlpool to get tech out and that was 3 days ago and no sign!
    No problem at outlet either.
    After 3 Days Whirlpool rep turned up, says its the thermostat and he needs to order new one for it. next week delivery :(
    Anyway thanks for relpies///
  • 828 Answers
Temperature control may have failed. Thermostat causes compressor to cycle on and off with temperature in the refrigerator section. If the compressor is not trying to run and is cold to the touch no power is getting to it. compressor is located in back on the bottom.
Additionally the defrost timer may have stopped working while in the defrost position. Locate the timer and rotate the clutch head screw clockwise a small amount and if the compressor starts and runs replace the timer.
Posted on Jun 18, 2008
  • 1 more comment
  • James Helmer
    James Helmer Jun 18, 2008
    Plug a lamp into the outlet where you normally have the refrigerator plugged in. If it lights you have power at the outlet. If it does not light or is dimly lit there would be a problem with the power supply to the outlet. If the lamp lights o.k. start at the plug on the cord for the refrigerator. observe the prongs of the plug to see if they appear burnt or the plug showing signs of melting. If these signs are evident replace the plug on the cord.
  • James Helmer
    James Helmer Jun 19, 2008
    It appears that your problem is in the electronic control board for this refrigerator freezer. Only solution I can think of in this case is having the control board replaced. You could try contacting Sears for service on this unit since Sears and Whirlpool are linked.
  • wizyrd Jan 17, 2011
    where would the timer clutch head screw be located?
2 Suggested Answers
SOURCE: how do I defrost my whirlpool ARC 5070
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Posted on Jan 04, 2010
Freezer not working but fridge works
It uses the same compressor for both. One of two things, the opening that is allowing cold air in the freezer , is closed or the freon is leaking out and it will be soon before the fridge is not working.
Feb 21, 2013 | Whirlpool Freezers
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
My whirlpool ART 900G fridge freeser, the freezer works but the fridge wont chill
Check the fan that moves the air from the freezer side to the refrigerator side. It is either stuck in ice or not working. Defrost the refrigerator for 24 hours and then restart it Listen for the fan operation be aware that the fan may shut off when you open the door, so listen closely. Defrosting it may fix or the fan may need to be replaced.
Nov 12, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Whirlpool FRS Side by Side Fridge Freezer
Hi Simon I saw that problem because you have a hole in the bottom of the freezer connecting directly on the wall of the fridge you need to block it ... because the air flow directly from the freezer 2 the fridge . Hope it was helpful.
Francois
Aug 01, 2008 | Whirlpool Freezers
Whirlpool 11.8 cu. ft. / 334 liter Upright Freezer EV120FXKQ Logo
427 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
