Question about Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12
I just replaced the remote panel from my Freedom 10 Marine Inverter/Charger with a Heart Link 2000-R battery monitor/alternator regulator. I have successfully installed the 2000-R but it doesn't "see" the AC in and it won't invert when I press the invert buttom. Is there a setup feature that I can't find?
  • 1 more comment
  • Glen Roger Nov 11, 2010
    No, everything works fine with the old Freedom 10 Remote faceplate. When I press invert, the light comes on and the inverter/charger begins to invert. It is when I switch to the Link 2000 that the inverter light does not go on when I press the invert button. Also, the AC IN and CHARGE, ACCEPT, FLOAT lights don't come on either.
    Thought of that. I traded the 6 wire telephone cable connector with a new one out of the box. Same behaviour.
    The Freedom 10 inverter charger can be controlled with the Xantrex Remote unit that comes as part of the package. I believe that the Link 2000 unit is compatible with the Freedom 10 unit and should be able to control the inverter/charger equally as well. I am unable to determine why the "Invert" button does not cause the led to turn on and off. I am also not able to determine why the "AC IN" and other status leds are not functioning properly.
  • 643 Answers
Was it working correctly at some time in the recent past? (i.e. not a new installation and/or changed wiring), the "Invert" light is off on the panel and will not come on when you press the button, battery voltage is between 10V and 15V and you don't have a bad battery/cell that pulls the entire bank down the instant the charging voltage is removed, and the unit is well-ventilated and not in thermal overload, the problem is most likely an internal failure which will necessitate taking the unit to a factory authorized service center, since Xantrex does not sell parts or schematics to the general public.
Posted on Nov 11, 2010
  • 2,427 Answers
I dont think there is a setup feature..
1.) ensure the inverter is getting power from the ac, use a multimeter to check this.
2.) check Fuse
3.) check its in the propper operating perimeter (voltage amps, etc)
Check the unit itself is getting power,..
Posted on Nov 10, 2010
  • Rishi Roshan Ali Nov 11, 2010
    check the input to the 2000, See if there is a break in the wire, Its eighter that or its defective.
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
I need a replacement comm board for a Xantrex Freedom Marine 25-12 Inverter/Charger. The battery temp sensor got shorted out and probably caused damage to the installed comm board.
I have the same unit that the charging function just died on. If I can't fix it and have to buy a new one, you can have my comm board for free. Should know my status in ~ a week .
Jul 03, 2010 | Xantrex Technology Heart Freedom 30...
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
Freedom 20 Inverter / Charger
1997 monoco dynasty and the invorter heart interface freedom model 20 the problem we are having is the we don't get any powere from the electric outlet and the lights don't work and there is a reading in side on wall that tells you about your electricity and it reads overload my # 817-614-7576 donna
Feb 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Behaves irradically
Until the inverter is turned off completely, either via remote or on the front of unit it will draw power, it goes into standby mode. Waiting for a load. Depending on the remote you have, if you have on they turn off differently. A link remote or basic.
Aug 04, 2008 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12 Logo
162 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
