Question about ASUS M2N68AM PLUS Motherboard AMD Athlon X2 7850 Black Edition OEM Processor Bundle
CANT BOOT . ONLY PROCESSOR FAN MOVING. I AM H/W
CANT BOOT . ONLY PROCESSOR FAN MOVING. I AM H/W ENGG. I ASSEMBLE WHOLE PC 2 TIMES BUT STILL HAVE THIS PROBLEM. I PURCHASE PC IN APRIL 2010. GUIDE ME .............
  • 4,737 Answers
Disassemble the machine completely and clean the Heatsink fan, blow away the dusts from the motherboard, if possible use brush to wipe away all the dusts. Reassemble it, but don't connect or install anything on the motherboard except the the power supply, the cpu with the heatsink and the system speaker. Now plug in the mouse, keyboard and the monitor (please connect the monitor on the integrated VGA port on the motherboard). Plug in the power chord on the back and short the two terminals of the power switch pins on the motherboard's Front Panel connectors, i.e PWR and GND with a screwdriver or with any metallic object you think is suitable (shown below):
CANT BOOT . ONLY PROCESSOR FAN MOVING. I AM H/W - nonontech_33.jpg
Remember to switch on the mains switch (wall outlet connected to the power supply) and make sure both the power connectors on the mother is connected, i.e. 20 pins and 4 pins.
Check the status on the monitor and listen the beep codes (the system speaker is compulsory for this diagnosis). If you see anything on the display or if you could hear the beeps, note the beep sequence (let me know if it's not 2 beeps or 3 beeps, if it's 2 or 3 beeps, the proceed forward), Switch off the machine and install one memory stick (Ram) and reboot. If it was 2 or 3 beeps, then you should no longer hear them, if you still hear the same beeps, then try with another Ram on another SIM bank(s) [Ram slot] after the machine is put Off and boot again.
If you don't hear anything or you don't see anything on the monitor, then your motherboard is bad or perhaps the integrated video card is dead or it could be the BIOS chip itself. I would suggest you to replace it, as it's not worth repair. Buying a new one will cost you less then repairing this motherboard under such circumstances.
If you see or the beeps continues, try with another working Ram, it should definitely work if the Memory module on the motherboard is still working, otherwise.. I would again recommend you to replace it.
Well, in case if it's successfully booted or the display is ok, then proceed forward by installing the component one by one and reboot everytime you install a component or plug in connector (s). You'll be able to find out the culprit, whether the hdd, or the Dvd/Cd drive or the front panel switches or others.... Will need to replace or will need to repair.
Please update so that I will be able to assist you further.
Good luck.
Thanks for using FixYa.
Posted on Nov 10, 2010
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
My laptop Sony Vaio CS 320J is shutting down with out any notice(not proper shut down but poweroff while running) and not booting again for @ least 2 mins. recently this issue started and this is...
Remove the bottom pan to expose the cooling fan, clean all dirt out of the heat sink and fins,and clean fan, next remove the heat sink to expose the processor ic, remove the old thermal grease with rubbing alcohol, and apply fresh thermal conductive compound to the heat sink and processor, "not to much! just enough to cover the critical areas and assemble. In most cases this will solve the shutdown problem.
Apr 15, 2011 | Sony VAIO VGN-CS320J Notebook
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
My hp media center m7160n computer powers up, has a definite fan sound, normally the fan sound diminishes and the computer boots up. For the last several months, the high speed fan sound would not diminish...
How did you clean it?
The last one I worked on had the fins of the Heat sink totally blocked with dust. This will make the fan scream trying to push air thru the heat sink to cool the processor. If it isn't cooled it will shut down in short order.
You must BLOW it out. Use a pressurized air can. Better if you have a compressor with a nozzle.
The other issue may be the interface between the CPU and heat sink is defective. Heat sink moved or become loose.
Of course by this time the processor could be dead also.
May 17, 2010 | HP Computers & Internet
After moving PC it won't fully boot
There is a possibility that something has shook loose during the trip to your new home.
You will have to take the side panel of the tower and check the CPU fan and heat sink to make sure it hasn't become loose or fallen off. Also check all the connections regarding the hard drive cables.
It is most likely the CPU fan and heat sink as when the processor reaches critical temperature it will shut down in a very short space of time.
Also give the unit a little time to settle down first.Leave it to settle for a couple of hours.
Regards.
Feb 25, 2010 | Computers & Internet
PC will not power on - fan turns briefly then stops
The easiest way to troubleshoot these syetms is disconnect parts one at a time and try booting each time. This issue may be power related, but may not be the power supply but rather a component pulling too much power and causing a shutdown. First disconnect the ram, one stick at a time, then move on to the cd or dvd player, move through the components to see if any of them are the culprit. Test the PSU to see if it is putting out the proper voltage. Check the processor heatsink for air blockage and remove the processor and replace the thermal paste on the processor and heatsink. An initial high temp will cause the systym to shut down. I am thinking it is your power supply, because when you turn the system on, even if the system doesnt boot, the fan and the components should continue to run. Lets try disconnecting components first, then move on to checking the PSU voltage.
Nov 08, 2009 | Acer Aspire RC500 PC Desktop
Power pack fan not booting but there is power on motherboard
Do you mean the power supply fan or the processor fan? Of the assemblies in a desktop, the power supply is the least reliable and the internal fan the most unreliable part. Since a failed fan can allow other parts of the supply to degrade, I recommend replacing the supply, not just the fan.
In eMachines, these are standard form factor (ATX) supplies so you would only need to order the same or higher power rating to have it compatible with your case.
Jul 23, 2009 | E-Machines eMachines Desktop PC
P4 processor reboot
pc turnoff and fan clip conect your pc.........
Jan 17, 2008 | Computers & Internet
No boot, got continuous beeps at first, reset my 'savage2000' VGA card
The solution may be to locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
Jan 22, 2007 | Gigabyte GA-8SR533P Motherboard
ASUS M2N68AM PLUS Motherboard AMD Athlon X2 7850 Black Edition OEM Processor Bundle Logo
447 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
