Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
I have a Liftmaster garage door opener & remote. The remote began to work only intermittently. I replaced the battery (I didn't reprogram remote when battery was changed & remote worked for a while) & again only intermittent success to open or close garage door with remote. Hardwired button works fine. Has the contact switch died in remote? Entire garage door opener system was replaced 2 yrs. ago to Liftmaster brand. Any ideas or suggestions? What would you do?
  • 504 Answers
COULD BE A BAD REMOTE, I WOULD TRY ANOTHER ONE FIRST.
COULD BE A FREEZER ETC. PUTTING OUT INTERFERENCE.
OR
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Posted on Nov 11, 2010
I have a Lift-Master Security remote garage door opener. It has a new battery. Can it be reprogrammed or do I have to replace the remote?\r\nThank you for your assistance. Model number971LM. It will...
ANY TIME YOU CHANGE THE BATTERY IN A REMOTE IT NEEDS TO BE REPROGRAMED.
ON THE CIRCUIT BOARD YOU WILL FINS A SQUARE BUTTON.
PRESS AND RELEASE NOW HOLD DOWN THE BUTTON ON THE REMOTE FOR ABOUT 20 SECONDS. WHEN YOU PRESS THE REMOTE THE NEXT TIME THE DOOR SHOULD OPEN.
Oct 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
This Liftmaster 61LM remote is the equivalent remote t? the Sears Craftsman 139 model number listed above. It h?? dip switches inside the battery compartment that ??? match up w?th ???r existing remote t? m?k? ?t open ???r garage door. There is also a set ?f dip switches ?n the overhead opener itself ?f ??? n? longer h??? a working remote. It ?h???? b? easy t? find ?n the garage door opener. This remote operates ?n a 390 MHZ Frequency, and works ?n models fr?m 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB Sorry about the lousy question marks in the last post
May 13, 2010 | liftmaster Chamberlain Garage Door Opener...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster Security Garage Door
your car remote should work even from inside the garage... if not, just take it off the visor and go outside the front door and point it at your garage to open it. This is only a quick fix. You probably need to replace the batteries in your keypad or reprogram it.
Jul 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
613 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
