Question about Jack Lalanne Power Juicer (Stainless Steel)
Accidentally put in blade before filter when reassembling it and now it seems the blade just keeps spinning and I cannot remove it with the crecent tool. It is stuck.
  • sej620
    sej620 Aug 20, 2012
    How did you ever get it off? I am having the same problem :(
  • 1,711 Answers
For these cases there is a special tool with three callipers and a centre screw. With this tool you can pool the blade. On other way is hang the juicer on two metal flat very thick sticks which can be secure in two bricks or thick wood blocks which must be just one inch higher than the height of your juicer., one in one side and second in other. And by using a plastic or wooden hammer you hit over the axis so the blade will become loose and come out.
Under the juicer you can put something soft like a towel so if the juicer falls down to keep it safe.
Posted on Nov 10, 2010
The blade to my Jack LaLanne juicer was screwed on without the filter in place. Now the blade spins but will not come off. How can I get the blade off?
it came with a blade removal tool,, if not take a dish towel and place it over the blades ,push down and turn it will come off
Oct 19, 2010 | Juicers
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
How do you take the filter and blade off to clean? it came together easily, but having trouble taking it apart...
It should unscrew in the opposite direction that the blade turns. Check the blade direction by momentarily spinning the motor with it's own power (don't touch it!). Once you know which direction it goes, unplug it and turn the blade in the opposite direction to remove.
Aug 19, 2009 | Jack Lalanne Power Juicer 250 Watts
No crescent tool included with purchase to remove the blade
Make sure the Juicer is unpluged. What you need is the cresent tool or two metal objects to place in the two holes opposite each other and press down the metal objects in the holes while turning counter clockwise. It kind of acts like a lock and key system.
Jul 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Sometimes it will spin out of control the lid pops off and its scary! This seems to happen when I juice cucumbers even though I take the seeds out. Yesterday I juiced lettuce leaves, celery (2 sticks),...
DROP THE FILTERS. FRUITS AND VEGETABLES HAVE TO BE FED SLOW
AND STEADY. IF THE JUICER IS OLD THE
GAP BETWEEN BLADE AND CHUTE MAY
BE TO WIDE LETTING LARGER PIECES
THRU AND THROWING IT OUT OF
BALANCE. USING ONE FOR 19 YEARS
AND THEY ARE TRICKY.
Jul 16, 2009 | Acme 5001 Supreme Juicerator Juice...
NutriSource juicer
The support number is:
866-290-1851
Oct 01, 2008 | Back to Basics NS1000 Nutri Source Juicer
Jack lalanne power juicer
I seem to be able to put the crescent too in but the blade just spins and doesn't seem to be connecting to anything to pull it out. Talk about frustration!!!!!!!!!!!!!!!!!!!!!!!
Jul 21, 2008 | Jack Lalanne Power Juicer 250 Watts
Cutting Blade won't come off
I do not have a tool so I used two pen tops, turned the blade counterclockwise while ensuring the filter basket stayed put. It worked well
Apr 16, 2008 | Jack Lalanne Power Juicer 250 Watts
How to dissassemble Jack Lalanne Power Juicer?
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
Jan 01, 2008 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer (Stainless Steel) Logo
125 people viewed this question
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
