Question about Karcher 2500 PSI Pressure Washer
I have the Troy-bilt 2550 psi pressure washer with a Briggs & Stratton engine (model# 020337). Originally, it would start and die immediately. I took the pump apart and cleaned out the unloader valve and now it will stay running. But now, when not cranked, water flows through just fine. When I crank it, water stops coming from nozzle and the relief valve eventually lifts. I'm afraid I put the ball and spring in wrong (in port directly under the 3 cylinder ports) because when I take it out completely, water flows but with no pressure. How should it go in or am I completely off base? Thanks!
    Scholar:
  • 100 Answers
I would replace the internal part of the unloader valve, it is known as the unloader seat, I can order you one it would take 2-3 days, Part number is 193972 price is $45.06. If you are interested in ordering one send me a email at justin@wmpcs.com with the information that I just gave you.
Another thing that you can check is the outlet check valve, the tube that you screw your high pressure hose onto has a valve built into it, if that valve went bad or if there is something stuck in it you would also have this problem. If you take the tube off the valve will be right where you screw that pipe onto the pump, the valve is part number 190592, price on this is $8.16.
Posted on Nov 10, 2010
3 Suggested Answers
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
  • 1388 Answers
SOURCE: I have a Troy Bilt
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Posted on Jul 02, 2011
Troy bilt 2550 psi pressure washer My friend gave
Try this link. I think you'll find what you're looking for.
http://www.troybilt-gen-pw.com/owners_manual/
Nov 04, 2013 | Garden
I have a Troy Bilt 2550 psi Power Washer with a Briggs and Stratton 675 Series, 190cc engine. Could you tell me what kind of oil I should use.
Jul 02, 2011 | Garden
Need to know where oil drain plug is on 6.75 hp Briggs & Stratton engine on 2550 psi troy bilt pressure washer!!
Aug 07, 2010 | Briggs Stratton 020273 Elite Series...
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Karcher 2500 PSI Pressure Washer Logo
2,318 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
