Question about Barnett Crossbows Barnett Revolution Crank Cocking Device
Lost crank handle can this be purchased seperate?
How to remove window handle on 1996 saturn sl
stick flat head screwdriver inbetween crank and interior of door, seperate and look carefully to see metal C clamp holding window crank on... remove that, usually using needle nose plyers or if you have a hook pick also works real well but thats a bit of a specialty tool. needle nose work but take patiance :) just grab ahold and pull, should not be hard to pull on, and make sure NOT to bend it, thats the only thing hold ing that on!
Jul 28, 2012 | 1996 Saturn SL
How do remove the window crank so i can remove the door panel?
There is a little clip behind the crank where it goes thru the panel. the clip looks like a "C" shaped clip..you'll need a small pick or screwdriver to pop it out..there is a tool specially made for this and can be rented fron autozone...once the clip is off crank pulls right off...when re-installing..put clip back on the crank , place crank over shaft, and press on till you hear it click.......ps..be careful as to not lose the clip...it's spring loaded and may go flying when you pop it off...if you do lose it they are readily available
Jan 20, 2011 | 1994 Buick Skylark
How do I take the window handle to get the door panel off?
there is a C clip that slides over window crank locking it on to the window crank shaft. A strong tool like a dentist pik that has a hook on it works great !! Or a small long flat screw driver, push in on the door panel by the window crank and look between crank and door panel, you will see this clip on the back of handle. push or pull this clip off the handle and the handle will pull off the window crank shaft. keep an eye on this clip as it like to take flying lesson.( wear safety glasses.) When installing clip, install on window crank in the slits or grooves and just push handle onto crank rod. you might have to hit with rubber mallet (TAP TAP ) make sure it locks on.
Jan 14, 2011 | 1993 Nissan Pickup
How do I remove the interior window handles. This
the inner handles are held on by a spring clip that captures the shaft of the window regulator to the handle.
most parts houses have a tool to remove the clip without damage to the door panel or handle.
Jul 27, 2010 | 1991 Oldsmobile Cutlass Ciera
How do i get my spare tire off my 2005 ford ranger xlt
hole thru bumber put rod thru turn to let down, by the license plate
Feb 04, 2010 | 2005 Ford Ranger
Self propel always engaged
you may have lost the spring that pulls the transmission drive belt down or have the cable adjuster too tight.word of caution here, the cable goes thru the engagement lever and if you overtighten it the lever will crack or break. if it does the complete transmission will have to be replaced.seems they dont make the lever avalible seperate.
Jul 09, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Need an cable for one of my seperates.
e-bay, richersounds, most hifi/electrical shops.
Jun 26, 2009 | Audio Players & Recorders
I need to replace the window crank handle (manual)
You need to remove a horsehoe shape clip behind the handle. Look at the new one, there should be a groove that it snaps into. You can purchase a special tool that slides behind the crank handle and pushes the clip out (only costs a few bucks at parts store), or if u are patient and careful, a couple of small flat screwdrivers placed behind the window crank, u can (but it's tricky) push the clip off. Another method is a piece of wire bent at one end w/ a hook, slide in and hook the closed end of horsehoe clip. good luck! and yes control that brute strength! countrycurt0
Oct 13, 2008 | 1994 Jeep Grand Cherokee
Barnett Crossbows Barnett Revolution Crank Cocking Device Logo
81 people viewed this question
Top Barnett Crossbows Sport & Outdoor - Others Experts
Are you a Barnett Crossbows Sport and Outdoor - Other Expert? Answer questions, earn points and help others
