What are the color cartridges to be inserted eg blk red magenta does anyone know what they should be and the order they should be inserted?
    President:
  • 2,666 Answers
Depends on what printer.
Posted on Nov 10, 2010
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
When printing images from my Canon MG6150 it isn`t printing any magenta/red shades and the magenta cartridge is brand new. Every other color is printing fine. Anyone know what this problem could be? Is it...
Use the printer application to clean the cartridge and print all the test. If the test are wrong. You should change your cartridge. Maybe you have a bad store cartridge or expire one.
Apr 30, 2011 | Canon Office Equipment & Supplies
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Kodak Easyshare 5300 Printer prints magenta tinted pictures
1 800-474-6836 this is a support number for HP products. They may be able to help you here or guide you to another source.
Feb 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
My hp 2600n color laserjet leaves RED DOTS on the printed document. What should I Do?
look at the red cartridge do you see any dots on it ? is it only when you print? what about if it's just Blk & wht?
Jul 21, 2008 | Sharp AR-5320 Black and White Copier
12 people viewed this question
jasbo
jasbo
