Question about Xerox Office Equipment & Supplies
My Zerox copier is making black shaded copies. How do I fix this problem
    President:
  • 2,072 Answers
Not knowing the model number I would think, either the drum unit needs replaced or the toner.
If the pages have repeat images is would be the fuser.
Posted on Nov 10, 2010
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Just started making gray shaded copies, no messages on printer
if it is a black/white printer then the black printer cartridge could be the problem or the drum unit.
Jan 03, 2011 | Office Equipment & Supplies
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ir 8500 cannnon copier black shade on paper
hi dude i dont think u have problem with drum cleaning blade coz it not making trouble for me from last 5years.
just replace the crona wires both charge and transfer and clean the whole scanner mirors .
thanks
May 16, 2010 | Canon imageRUNNER 8500 Copier
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
Printing problem
Have you tried changing the cartridge or refilling the black and colored ink cartridges?
Jul 25, 2008 | HP DeskJet F380 All-In-One Printer
Zerox workcenter m151 when i print i only get on both sies of page light coverage not readable copy if i copy with cover open i get two solid black strips do i neeed a new drum or is it something...
Your toner is empty and just not indicating it's empty.
There is a light sensor and windows through the cartridge. Sometimes there is a little ink left on the window and it doesn't report empty.
Jul 17, 2008 | Xerox Office Equipment & Supplies
400S Black lines at top of copy
Sounds like the drum is worn out. Usually do 60-70K before replacement. Shading more noticeable at top of copy. Could also before worn upper fuser roller.
Nov 09, 2007 | Canon imageRUNNER 400S Copier
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
