Question about Pioneer Televison & Video
I have a Pioneer Plasma Display model AXD1459 and I pressed The Standby /On button on the side of the Display, IT made a weird sound and now it doesn't want to turn on again. I've tried by turning The Main Power switch on the back off and on, as well as unplugging the power cable and still doesn't work. The Standby light on The bottom left on The front of The display is turning and off. Could you please help me out?
  • Pioneer Master
  • 11,800 Answers
The weird sound was caused by the power source being so overstressed that the emergency shutdown was engaged. This is what happened: a part inside your tv was failing and, when you tried to start the tv, the sudden electric shock caused by the starting of the power source has been too much so it finally failed in a big way - it shorted. This short has caused a big spike it the current drawn from the power source, way more that it's designed to deliver normally - generating the sound you heard. This spike in the current has triggered the protection system into action - the power source has been forcefully shut down.
Since the protection system is now activated the only way to reset it is to eliminate the short. The only way to do that is to open the tv and test the components, find the failed one and replace it - a job for a skilled repair man.
Posted on Nov 10, 2010
My pioneer sx-316 multi channel receiver is off on protected mode what do I do to restart
I read the instructions perhaps slightly differently perhaps. I take the instructions to mean first hold down tone and then hold standby/on key for three seconds. Have you tried doing it as two steps?
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the  STANDBY/ON button for about three seconds.
3 When you see 'RESET?' appear in the display, press the ENTER button. OK? shows in the display.
4 Press SETUP to confirm.
Feb 03, 2015 | Pioneer New Original SX316S Remote Control
Pioneer plasma light wont come on just stays in standby and when i push the standby button it comes on
Sounds like main board fault. Contact the service center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Pioneer PDP-5080HD 50 in. Plasma HDTV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
Need a remote control for Pioneer model PDP-503CMX
Here you go sir/mam
http://parts.pioneerelectronics.com/part.asp?productNum=AXD1459
Sep 24, 2009 | Pioneer PureVision PDP-503CMX 50 in....
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
How do i reset my Pioneer SX 316 Surround Sound System. i lost the owners manual.
1. Switch the reciever into standby.
2. While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3. When you see RESET? appear in the display, press the ENTER button. OK shows in the display.
4. Press SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
Aug 08, 2008 | Pioneer Audio Players & Recorders
Televison & Video Logo
389 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
