Question about Pride Jazzy 1103 Ultra Standard Power Chair
Jazzy was unpluged and without power for days. However, now when charged its not working at all. How much more should it be charged? Is there something that might be loose somewhere? We got this new Jazzy in March 2010?
  • 692 Answers
Imae Your chair is still under warranty but not the batteries they usually have a 6 month warranty. I would contact your provider (where you bought the chair) and have them check it for you. Hope this helps
Posted on Nov 10, 2010
Jazzy elite service technician
The batteries may be too discharged for your charger to operate correctly. Use a 12 volt battery charger without automatic charging function and use it to charge the batteries individually not connected together. It might take 2 or more days to do it , before the original battery charger will work normally. There's a chance the batteries are damaged and won't charge at all.
Sep 07, 2014 | Health & Beauty
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
My jazzy was sitting for a year, without battery charge. now, the batteries won't charge. what shoul i do?
I strongly suspect your batteries are dead. The unfortunate part is that the gel batteries used in power chairs will not usually take a charge after they are completely depleted. The only solution is to load test the batteries and replace BOTH of them even if only one tests bad. ( I think you'll find that both batteries are dead)
Sep 05, 2011 | Pride Mobility Products Jazzy Select
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
Nov 12, 2009 | Health & Beauty
How do you reset the dc charger on a jazzy 14xl the batteries have been replaced? thanks
Chargers generally do not need to be reset. But in some cases if you may want it to start a Bulk charge.
If the charger is plugged in to the mains and ON, Then switch OFF and leave unplugged for 2 - 5mins.
Meanwhile Switch Jazzy ON and try and put some load on the batteries by taking it for a short but power consuming trip usually by going up hill.
Then plug charger in and switch on and the charger should initiate a full charge sequence.
Aug 06, 2009 | Pride Jazzy 1103 Ultra Standard Power...
This is a Jazzy powerchair.
What model Jazzy is it? A soft idle??? Like a purr or is it a grrr? Purr is okay, gurr, bad.
During a thunderstorm, any and all electronic equipment should be either unplugged, or put onto a power strip that has a replacement gurantee for any damage as a result of a storm, etc.
Yes, you can take a shot through the charger and it can whach out your controller, and cost about 1,200 bucks to fix. If you are lucky, it'll trip the circuit breaker on the chair.
Jul 07, 2009 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
147 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
