Question about Schaerer Siena Espresso Machine
Flowmeter error - Schaerer Siena Espresso Machine
  • 38 Answers
A blockage of water flow
Posted on Dec 09, 2011
Miele Dishwasher won't run. G4220. Fills and empties ok. Originally had F13 error. Circulation impeller has been checked and turns ok.
Tracey, the original poster found her own answer to the problem which is listed here for those with the same problem.
Given the error changes with each flowmeter board I feel I am on to something.
Thanks, Tracey Solved this.
When we checked the circulation pump, we had not replaced the power connector to the pump. Once we plugged that back in all worked okay. So... the fix to the original problem was replacing the flowmeter board.
May 11, 2017 | Miele Washing Machines
How to fix it error 05 on krups ea8260
Flowmeter fault (wires reversed, connector offset, ...)
Switch or distributor switch control fault
Drop of water on the flowmeter connector
Pump fault
Water flow blocked: hose caught, strainer missing (tank valve not actuated), tank badly connected
Nov 17, 2013 | Coffee Makers & Espresso Machines
Flowmeter Error
Before you go ahead to check the flowmeter, make sure that the water pressure is OK.
I had the same problem with mine, it is normal for that message to come up if the boiler is empty, but has to go away once the machine stops taking water or filling the coffee boiler.
Nov 19, 2012 | Franke Evolution
The LF error code keeps appearing which is which is no water or insufficient water. However it has plenty of water. What's going on?
The part called the FLOWMETER is what it seems to defective,the flowmeter is what measures the volume and pressure of the water coming in,so with good water pressure and sufficent volume of water coming into the washer the flowmeter would need to be replaced.
To replace the flow meter,remove the screws from the back of the top and slide the top to the back and lift it off and the flowmeter will be attched to the rubber hose directly beyond the nozzle to the water inlet valve. This is what the flowmeter looks like,in the picture below. The part number for it is
W10110225 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Flowmeter error on an Ambiente Espresso Machine for Dunkin Donuts
Flowmeter A restriction of water flow.. is the drink interupted when you see this message if so replace flowmeter.. if not look for the blockage of flow coffee in the inlet tube to brew group,, calcified hot water boiler inlet tube plugged pistons..
Sep 27, 2010 | Schaerer Siena Espresso Machine
Washing then it beeps and H and F flash, washing machine stops and only the flashing H and F appears..............
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter sits right in front of the water inlet valve and is attached via a hose and is off to the left side of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this error code. Sure hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
Fh error code
The F/H code means the unit isn’t detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I’ve seen this harness jiggle loose and cause problems.
Jun 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
May 20, 2008 | Kenmore Elite 45986 Front Load Washer
Schaerer Siena Espresso Machine Logo
169 people viewed this question
Top Schaerer Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Schaerer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
