Question about Haier Refrigerators
My little Haier refrigerator wasn't working this morning when I came in to work. I didn't notice anything wrong until I saw the puddle of water in the bottom. Is it possible that I left the door slightly open and it overheated??
    Guru:
  • 157 Answers
Yes the door was open and not properly closed.
Posted on Nov 10, 2010
  • valerie_m922 Nov 10, 2010
    So will it work again after it overheated? It hasn't worked all day.
I have a KitchenAid KFCS22EVMS that is going on 4 years. I recently noticed (by sound of water trickling and a wet floor) that the water feed line that runs up the backside of the refrigerator slipped out...
Right now it sounds like the water control valve is leaking and caused this ice buildup and even froze and pushed itself away from the rubber grommet that holds the water line in place to the the back of the refrigerator and into the ice maker. Can you see ice has frozen inside the fill tube that the water passes through just before it enters the ice maker? 67006531 Water Inlet Valve
I believe that the water control is leaking while it should be off, Sea Breeze
Parts manuals below
  • KFCS22EVMS00.pdf (1958.35 KB)
  • KFCS22EVMS1.pdf (2037.56 KB)
  • KFCS22EVMS2.pdf (2028.98 KB)
  • KFCS22EVMS3.pdf (2136.05 KB)
  • KFCS22EVMS4.pdf (2134.20 KB)
  • KFCS22EVMS5.pdf (2134.26 KB)
  • KFCS22EVMS6.pdf (2120.80 KB)
  • KFCS22EVMS7.pdf (2105.43 KB)
  • User Manual Page HERE
    Oct 10, 2013 | KitchenAid Refrigerators
    My Haier HLP21E top load washer is only one month old, and there is some leaking from under the machine.
    Check the hose clamps on the bottom. Sometimes the clamps are not all the way on or tight enough. I saw one that did the same thing.
    Aug 22, 2012 | Haier HLP21E Top Load Washer
    Hello. I recently changed my water filter (puresource2) on a side by side. The water coming out now is cloudy. It looks like little white particles floating in the glass. I didn't notice it that...
    If you can find a hose that will fit the water line you can flush it out. But the most likely problem is that the filter that you bought was defective and the white particles are coming for it. If you can test it without the filter, to see if the water is clear or not, will tell you whether you should take the filter back and complain.
    Jun 08, 2011 | Frigidaire FRS23KF7AB Side by Side...
    1 charger doesn't work. Set purchased from Sam's Club on 4-25-11. Didn't discover it wasn't working until this morning. LS6326-4
    Retun it for replacement under warrenty. Check your reciept or other doc for return procedure. May have to go to manufacturer.
    May 07, 2011 | Vtech Lands Phones
    We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
    Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator
    Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Feb 16, 2011 | Refrigerators
    I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
    Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
    Nov 14, 2010 | Jenn-Air Refrigerators
    99 Sunfire Coolant keeps dumping
    You need to find the source of the leak. it hasn't overheated yet because you keep catching it and re-filling. From your description, it sounds a lot like a bad water pump seal (part of pump) but without physically looking you can't be sure of that. when the pump seal begins to fail, internal pressure while running often will drive the seal tighter against the shaft stopping the leak. as pressure drops as the engine cools, the seal relaxes and permits seepage.
    With time, that will change and it will leak all the time.
    Oct 06, 2009 | 1999 Pontiac Sunfire
    Leaking water INTO fridge
    Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
    Jan 21, 2008 | Haier HTQ18JABRSS Top Freezer Refrigerator
    Refrigerators Logo
    104 people viewed this question
    Top Haier Refrigerators Experts
    John Tripp
    John Tripp
    doggzzz
    Level 1 Expert
    Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
