Question about Dell 1710 Laser Printer
Our Dell 1710 laser printer is producing a strange smell - it smells like diesel/kerosene fumes. Weird, huh? It seems to be working fine otherwise - no change in performance. Any ideas? kerry
SOURCE: Dell 1710 Laser Printer
i had the same issue, but i fixed it. For whatever reason the contacts that are inside the printer were not making contact with the PCB ( printed Circuti board ) on the underside of the drum... i fixed the issue by cleaning the pcb and re-aligning the contacts inside the printer.
Posted on Jan 25, 2008
SOURCE: paper cannot pass the Fuser/pressure rollers
The little rubber rollers can be taken off and turned inside out and I'll betcha that ****** starts worling.
Posted on Nov 17, 2008
SOURCE: paper goes half way through and then stops and registers paper jam!
http://www.fastprinters.com/ProductDetails.asp?product_id=LEX-56P1826
Exit sensor is broken , look for the same part for a Lexmark E330 if the URL dies.
Posted on Mar 26, 2009
SOURCE: I have Dell 1710 Laser printer. Toner and Error
You need to replace the toner. Printer shuts down when print counter reaches it's limit on the toner cartridge
Posted on Apr 24, 2009
SOURCE: after replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Posted on May 14, 2009
V70 1.6D 2011 smells of diesel after being parked
Take it to the dealer. They can run the codes on the car and find the issue. Do not give up yet!
Jan 24, 2014 | Volvo V70 Cars & Trucks
There's a strong smell (fumes) coming from the printer. I felt high the first day and I had a funny feeling in my throat on one side. Some say it smells like a hot blow dryer or burning smell. I need to...
The odor is coming from what is called the 'fuser' which heats and bonds the toner to the paper stock. There may be some light residue from the manufacture of the fuser roller which is heated to a high temperature to enable the fusing to take place. It may linger for several days but is unlikely to be hazardous in nature otherwise Samsung wouldn't allow it to remain on the assembly. Laser printers often smell 'hot' due to this process but I have not heard of any hazard caused by fumes. One caveat though; the fuser roller is coated with Teflon or an equivalent coating. I nearly died from Teflon which was in a gaseous state many years ago but it was exposed to temperatures of greater than 450F which is dangerous since the effect is that of a nerve gas called phosgene. Since that is a temperature one can easily reach on a stove-top, we have NO coated cookware in our home.
If you notice that the plastic near the warmest place on your machine feels uncommonly hot, it might be best to shut it down since it may be possible for the thermostatic control to fail so the fuser is heated to an abnormally high temperature. I'm fairly sure there is a thermal fuse to prevent catastrophic failure but wouldn't count on it.
Mar 29, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Replaced rotor on my 115 ready heater now it puts out way to many fumes,it burns my eys.any suggestions
The fuel/air mixture is not right.
  • Start by setting the pump pressure to factory specs.
  • Stop all air/vacuum leaks between the air pump & nozzle
  • If the problem persists, replace the nozzle. Desa recommended annual replacement. Simply stated- the nozzle wears out to a point that the fuel is a spray rather than a fog and the fuel can't burn completely.
  • You don't state the type being burned. Diesel smells more than kerosene.
Feb 05, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Rennai gas unflued heater kerosene fumes
Have it checked properly - sometimes the reg won't open fully, but the heater will still run, but with improper combustion resulting in a funny smell.
Aug 12, 2009 | Heating & Cooling
Ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Feb 05, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Door inside and metal vent area smells strongly of fumes
Did you find an answer toyour question?
My microwave smells also of petrol in the same areas.
Jun 05, 2008 | GE JVM1653 Microwave Oven
Laser 72
Your manufacturer, Toyotomiusa, recommends that you tighten all the joints on the fuel line. Your owner's manual CLICK HERE contains detailed drawings showing the location of all parts, including the fuel injector. Your unit will need to be serviced by a qualified technician if you have tightened the connectors and still smell kerosene or find wet spots under your heater. It should not leak or smell of kerosene. If you're smelling kerosene, you should not operate the unit, because the leak may cause a fire.
Jan 15, 2008 | Rinnai Toyostove Direct Vent Heater:...
Dell 1710 Laser Printer Logo
137 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
