Question about Breville ESP8XL Espresso Machine
The heating element on my Breville Cafe Roma espresso maker no longer works. The water will not heat. I think I need a new element. Where can I purchase?
SOURCE: Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
Posted on Sep 18, 2011
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
  • 11 Answers
SOURCE: Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Posted on Aug 13, 2010
  • 11 Answers
SOURCE: I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
tatamall_dea
  • 4 Answers
SOURCE: Where can I find (and purchase) the "single wall" filter (single shot) for the Breville Cafe Roma
Hmm,Maybe you try here:http://www.busytrade.com/products-search/single-wall.htmlI hope this answer can help you.
Posted on Dec 09, 2011
Breville Cafe Roma , worked fine, stored for 2 yrs, now it will not pump. Powers on, heats up, but when the switch is placed on water or steam setting, no pumping sound at all, perfectly silent. One...
Just a guess, water is usually like oil (a lubricant) in your pump, so standing 2 years it's "dry" or there is no water being supplied or there is a screen or filter that is plugged.
Possible no power to pump, or an inline fuse or circuit breaker to the pump and heater has blown. Or a temperature safety sensor has disabled power to pump and heater. Owner's manual might help.
Feb 10, 2018 | Breville Coffee Makers & Espresso Machines
I did something wrong: I left my machine running for about 20 minutes without any water. The machine was turned on and the switch was turned towards the "coffee" sign. The red/orange lights are still...
Hello 'lord tatien', from my research I suggest you call 1-866-273-8455 8a to 5p Pacific time. I couldn't find technical info on line. You may try this, unplug unit overnight. It should have an internal over/temp power breaker on the heating element witch would reset after cooling off.
Oct 21, 2010 | Breville ESP8XL Espresso Machine
May 20, 2010 | Breville ESP8XL Espresso Machine
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Water squirts from the top instead of through the coffee
The underseal / group gasket is damaged and needs to be replaced.
Jul 23, 2009 | Breville Die Cast 800ESXL Espresso Machine
Plastic baffle came out of drip tray when moving.
I think it should fit in the back of the driptray.
/Mirran
Oct 04, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
1,005 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
