Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Down load the new firmware and install it in your router.
http://kbserver.netgear.com/products/WGR614.asp
Use UPnP. If your router supports this. Turn it on. The router will work out the ports it needs to open for Xbox live. If your router does not have this feature, check the manufacturers website for the latest firmware. (also make sure portforwarding and/or DMZ is turned off as they interfere with UPnP)
