Panasonic Lumix DMC-TZ3 Digital Camera
Problem for Panasonic Lumix DMC-TZ3 Digital Camera
Camera lens
By Eru21 on Jun 17, 2008
When I turn my camera on, it shows a black screen, apart from that everything else works. Please help, thanx heaps
Solution #1
posted on Jul 19, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Try taking the lens cap off
Solution #2
posted on Jul 18, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
For how long is the black screen displayed? If it is displayed for only a few seconds then it should be OK.
Solution #3
posted on Nov 05, 2009
Not Rated)
dupalopez
Rank: Guru  Panasonic Expert
Rating: 93%, 19 votes
Does the camera take pictures?
If you take the camera near a lamp, can you just about see menu items on the LCD?
If so, it's possible that the backlight ribbon cable slipped out of the socket. To check open up the back of the case and carefully lift it up a bit just to see the ribbon cables. The narrow one is used for backlight. Try to disconnect it (open the tiny black flap in the connector) and connect it again (close the black flap). Have a quick look at the connectors on the ribbon cable and make sure they are clean. If it still doesn't work I'm afraid most probably you have a faulty backlight and will need to replace either the whole LCD (easy) or just the backlight (fairly fiddly job). In any case, you'll probably need a donor camera (ebay ;) to scavenge for replacement LCD.
Good luck,
Raf
Was this helpful?
Yes
No
Popular Solutions for Panasonic Lumix DMC-TZ3
Questions and Unsolved Problems for Panasonic Lumix DMC-TZ3
Do you recommend Panasonic Lumix DMC-TZ3 Digital Camera?
Answer
Answer
After being dropped, shutter will not open & close. Can you buy a shutter part? Camera... (More)
Answer
ring around the lense is bent and lens won't telescope open anymore
Answer
The shutter is not opening all the way....so you see dark edges on the pictures. What should I... (More)
Answer
I lost the PHOTOfunStudio CD for my DMC-TZ3. Where could I get that?
Answer
Panasonic Lumix TZ3. I can´t find pictures. About 25 of them are missing but when I tried... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Lumix DMC-TZ3...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
