I HAVE A MIKOMI 15" FLAT SCREEN LCD TV ONLY 3 MONTHS OLD. WHEN I TURN IT ON I GET ABOUT 1 SECOND OF NORMAL PICTURE THEN IT BLACKS OUT, BUT THE SOUND STILL WORKS. HOW CAN I FIX THIS?
    Brigadier General:
  • 3,614 Answers
First try to adjust the tv setting / color settings of the tv. and let me know here again.
Posted on Jun 17, 2008
    Master:
  • 638 Answers
Display problem on the main board .check it out
  • 2 more comments
  • hemant somaiya
    hemant somaiya Jun 17, 2008
    Sounds like a common problem where the Horizontal Output Transistor shorts due to heat, loading by a partially shorted flyback or yoke or old dried heat sink compound. If the HOT is ok then there is probably a short in another component. This can be determined in most cases by isolating each module one at a time. In other words disconnect the audio circuit and try, disconnect each crt separately, etc. If no shorts are determined check the power supply for proper output voltages. All this would need to be done by a tech or someone familiar with the process. Repair cost should not be that much compared to the cost of a new set.
    rate the solution as FIXYA if it helps you understand and solve your problem.
  • hemant somaiya
    feel free for further assistance.
  • hemant somaiya
    keep me updated
  • hemant somaiya
    hemant somaiya Jun 18, 2008
    any updates
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
KDL-32S3000 Problem. We broke remote, so got a new one coming. However, The screen will be normal for 15 seconds or so and then a black bar will appear at top. On the left top of the black bar it will...
its asking you to adjust power on the main power box it sould be under power saver adjust level it to low it should be in your menue and then your main power setings.
Feb 06, 2011 | Sony Televison & Video
Hi! A few months back i bought a Philips 52'' LED-TV 52PFL5605H Full-HD, 100Hz Tv to my computer and it works good. The only problem is everytime(not always. 8 out of 10 times maybe) the screen is just...
Unfortunately the video you are giving the tv must be one of the last systems the uProcessor in the tv checks. It takes about 15 seconds to detect signal/no signal for each system. Good old automated technology!
Dec 31, 2010 | Philips Ambilight 2 52 in. Flat-Panel LCD...
I have a Poleroid 19 inch flat screen. I turn it on and the picture is great but after 15 seconds there's a little pop sound and the screen turns black but you can still hear the sound perfectly. If I...
The tv have 1 or 2 long boards call the LCD inverter boards.These 1 or 2 long inverter boards are dead.That why the LCD screen not getting a backlight to produced a picture.Replaced those 1 or 2 long LCD inverter boards,will get a baklight back and have picture.Tries websites like Shopjimmy.com,Ebay.com buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Aug 18, 2010 | Polaroid TLA-01901C 19 in. LCD TV
My Samsung 47 has a black film covering 1/2 the screen for about
Samsung only makes TVs that last 2 years, mine also has the same problem. Throw it away and buy a cheaper disposable TV, despite all the hype Samsung is just another cheap and nasty manufacturer who uses its customers as product testers. Why do you think they keep changing model numbers every week ?
Jan 13, 2010 | Televison & Video
Sharp LC-46SB54U Keeps losing picture intermittantly
i believe your tv is getting overheated, possibly from dust getting onto the electronic components inside. or the inverter board for the lcd panel inside is going bad, alot of times it is the capacitors on the lcd inverter board going bad.
Jun 12, 2009 | Sharp LC46SB54U 46 in. LCD TV
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
